Sep 09, 2019, 06:32 AM
max z's Avatar
Some stats:
weight: 180 g
motor: Turnigy 2730 1300 kv
prop: 7x4
battery: 2s-0,5 Ah
wings incidence angle difference to tailplane: +3.5 deg.
motor down thrust angle referring to tailplane: -4.5 deg.
no side thrust
Sep 09, 2019, 03:54 PM
max z's Avatar
Made more flights today, moved the battery all the way forward and CofG is now in the correct spot. Down thrust could have been a bit more, but mixing elevator with throttle solved that to satisfaction. A great flyer!
Max.
Sep 09, 2019, 04:21 PM
For us He died, in me He lives
Jimmy JFlyer's Avatar
Very nice build Max!
If I can ask, what foam did you do your build with? Note sure if you said that already or not.
Sep 10, 2019, 03:00 AM
max z's Avatar
Jim, I am not sure since I was given a sheet by a friend. It is a bit floppier than real Depron, I believe it goes by the name of "Selitac" and is normally used as underfloor isolation.
Max.
Sep 10, 2019, 05:19 PM
Ok thanks for the info. What thickness would you say the wing foam is?
Sep 11, 2019, 05:55 AM
max z's Avatar
3 mm, all as per Thomas' plan, Jim.
Sep 11, 2019, 08:54 AM
Thanks again Max!
Sep 11, 2019, 10:21 AM
scratchbuilder
Thomas B.'s Avatar
Beautiful Junior, Max!
