This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Jan 26, 2014, 06:39 AM
Jack Crossfire's Avatar
IMU drift 4
After a 2 day process, an outboard IMU was fabricated.
A magic switch was installed to switch the UART between debug & IMU input. The bootloader started in 115200, then the mane firmware switched to 230400 for the IMU. That supported 1050 full readouts per second.
Mounted it on a foam pad under the board. It completely failed to hover.
Hard mounted it with less of a failure, but still unflyable results.
That leaves an amount of vibration coming from the airframe which no IMU can handle. It could be any number of the unchanged motors or propellers. A new airframe has to be built from scratch, but any future crash could throw it off again.
You just need to have enough replacement motors & propellers in the pipeline from China to change everything out when the IMU starts drifting. You can't exactly buy anything locally.
Jan 26, 2014, 09:11 AM
is that a downward facing cam for pos hold ?
Jan 27, 2014, 03:39 AM
yes
