This thread is privately moderated by Nitro_Nancy, who may elect to delete unwanted replies.
Jan 23, 2014, 06:12 PM
New Product
Airfield Sonic Piercer
RTF - http://www.nitroplanes.com/95a285-so...e-rtf-24g.html
ARF - http://www.nitroplanes.com/95a285-sonic-blue-arf.html
Airfield elevates the electric ducted fan jet plane to new heights with its new Sonic Piercer jet. The Sonic Piercer is a 800mm wingspaned plane that stretches about 940mm. Its fuselage is designed around a 64mm electric ducted fan unit driven by a screaming 3850Kv motor. Airfield took its foam engineering expertise and developed efficient intake and exhaust ducting allowing this potent combo to produce large amounts of thrust when powered with a 11.1v 2200mah battery. The result is a compact sport electric ducted fan jet plane with exhilarating performance and speed.
The Sonic Piercer possesses a level of fit and finish that is every bit as impressive as its performance. Quality EPO foam construction allows the entire skin of the plane to be smooth and slick. The sleek fuselage comes with decals pre-installed making build time much faster. The wings are semi symmetrical and have winglets designed into the tips for extra stability in turns.
The plane also features a working rudder to get that nose up during moderate to slow speed banked turns. The wings are reinforced with a carbon spar and has built it balsa sliders underneath to protect the servos if you just happen to have a sketchy landing. The wings are also attached via magnets to make transporting that much easier. The elevator is a full movement horizontal stabilizer giving it excellent elevator authority at high speeds.
The control surfaces are delegated by five precise 9 gram servos. The Sonic Piercer also has a steerable nose wheel to make strip maneuvers easy and convenient. Other features that make this plane easy to work on are a removable hatch giving access to all servos and battery compartment. The ducted fan unit also features a removable hatch allowing quick and easy access, should the fan unit need to be serviced.
This almost ready to fly version comes with all the electronics pre-installed from the factory. You will need an 11.1v 2200mah battery, li-po charger capable of 3s charging, and a minimum 4 channel radio system to ready this plane for flight.
Specification:
wingspan: 800mm/31.5in
Length: 940mm/37in
Weight: 750g
Thrust rate: 1:1
Configuration:
Motor: D2830B-3850KV
Fan Unit: 64mm Ducted Fan Unit
ESC: 40A Brushless ESC
Servo: Five 9gram servos
Jan 23, 2014, 09:21 PM
yew, another ready to fly jeez its getting hard to choose.
Discussion Airfield Sonic Piercer 64mm EDF 4s set-up? fastblade Foamy EDFs 34 Jan 15, 2014 11:49 PM
Discussion Airfield Sonic Piercer 64mm EDF Jet Review hobbypartz Product Announcements 1 Aug 29, 2013 06:43 PM
