This thread is privately moderated by Tartago, who may elect to delete unwanted replies.
Jan 09, 2014, 09:11 AM
Plane crazy
Tartago's Avatar
Mini-HowTo
Wing tip light lenses for Dynam Bf-109
The Dynam Bf-109 is a fine plane with some not so fine absence of details.
One of them is the lack of wing tip lights. She comes just with 2 leds protruding from the wing.
So I decided to make something I never did: Plastic lenses for the lights.
Jan 09, 2014, 09:49 AM
Fly it like you're in it
microlyn's Avatar
Great work Tart! I read another forum where they figure out which resistor works, I'll try and find it.
Jan 13, 2014, 01:40 AM
Plane crazy
Tartago's Avatar
Good find!
I'm planning to use the ultra bright corn LEDs from Hobbyking though. I'll post the results later.
Jan 14, 2014, 09:23 AM
How I learned to love the Bomb
quitcherbitchen's Avatar
Tart, did the blue foam survive enough to make more? Just want to know how well your plug held up. I was thinking of making AD-5 canopies using blue foam as the plug.
Latest blog entry: HK B-17 landing gear mod
Jan 14, 2014, 10:05 AM
Plane crazy
Tartago's Avatar
Blue foam is magic! I even did my Ju-87B canopy with a blue foam plug.
Just use some Vaseline as release agent.
Jan 14, 2014, 10:45 AM
Good to know. Thanks. I was ready to make a hard wood plug.
Jan 14, 2014, 06:50 PM
microlyn's Avatar
An old trick to keeping canopies clear is to pull a thicker white styrene sheet over the plug first, say, .040, leave it on and pull the PETG over top. Can the foam take the thicker styrene?
Jan 14, 2014, 08:16 PM
Plane crazy
Tartago's Avatar
I haven't tried that, but I used water base PU varnish as a filler and the canopy was of acceptable clarity.
It can be washed with water and dish washer too.
Jan 14, 2014, 09:54 PM
microlyn's Avatar
Thanks, I'll try that
Jan 18, 2014, 11:07 AM
microlyn's Avatar
Looks like a guy over at the Dynam 262 thread is using a 1/2 watt 680 Ohm resistor for the lights off of 4s.
Jan 18, 2014, 11:28 AM
Plane crazy
Tartago's Avatar
That's good info. Thanks.
Mar 28, 2015, 11:18 PM
Alpine Aero Sqdn.
619SixFour's Avatar
Good tips, will try this on my 109.
