Vulcan Black Widow X8 (foldable) 20+ Min flight
First off thanks to Alex at VulcanUAV for all the help and support on getting this thing ready for prime time.
In case you are not aware, this is the NEW Vulcan X8 (aka Black Widow), using (4) of the Z-arms from their other Multirotor builds, Mantis has (2) Z-arms. This allows unobstructed views for any camera you may have because it raises the props up above the frame. Another cool thing is the arms can be folded inward for transportation purposes as shown in a few pics below. The goal here is to create a redundant multi that can support a Movi camera rig with a Red Epic with somewhat decent flight times. Another thing I really wanted to try was the DJI A2 flight controller, since it has a built in RX that supports Futaba FASST, this would eliminate one extra piece of equipment as well. I will be installing the DJI retractable landing gear on this, but at this time I just have the 390mm landing gear for testing purposes. List of Parts: Black Widow 900 folding frame 12mm rail mount 250A PDB Tiger U5 400 Motors Maytech 40A Opto ESC - SimonK Flashed Tiger 15x5 Carbon Props DJI A2 Flight Controller 390mm Landing Gear (2) MaxAmps 10900Mah 6s batteries Futaba 8FG Total weight - 12.5lbs In the Works: DJI Retractable Landing Gear Movi Freefly Camera Gimbal Allied Drones Quick Release Echo plate for Movi |
Here is a 2nd round of photos. This includes balancing the props with gorilla tape underneath for weight balance (horizontal), and balancing the hub out with hot glue for vertical balance. Now, no matter what angle you set the prop at, it should have little to no movement.
I have also posted pictures with props now attached to the X8 and have taken some measurements, both unfolded and folded. Attached is also a pic of the dual batteries I will be using. I also added pipe insulation to bottom of landing gear to cushion it a little bit. |
nice build so far. didn't know that there's a centerplate for folding the arms. didn't find it in alex's shop either. how much are they? what about that folding mechanism - can you really thighten it down, so that the arms wont move/vibrate in operation?
interesting thing. i'm also converting my flat8 into a vulcan x8. |
I have been thinking of getting a Vulcan Mantis for awhile to fly a Small DSLR but storage space has held me back. This configuration looks like the ideal solution to having a first class machine and being able to transport and store it easily. Alex is a great dealer and has helped me a lot in building smaller DJI upgraded machines.
As far as the folding mechanism, I have not flown this yet as I'm almost done with the build, hopefully get it in the air this weekend. But, Alex feels that these bolts should be sufficient enough to hold it in place by using the small carbon piece and washers to spread the load and increase the friction (don't forget to tighten though ![]() More to come... |
I am building a big vulcan octo with U7 motors, and have 2 of the Mantis arms, how big of a prop can you run on the underside of that arm? would a 16",17" or 18" fit? I'd convert it to a 4 mantis arm X8 in a heart beat.
edit: i'm running mt3515 motors |
Using that one pic, I'm thinking maybe 17 or 18" props could fit!
No? |
maybe theres a difference in angle between the long and short z-arms which would matter?!? |
Yea I was "Guestimating" I'm using U7's and they are HUGE, I'm going to investigate this on my rig when I get home.
