Jan 06, 2014, 07:06 PM
Question
ECX Ruckus 1/18th Brushed 380
How do I take the slipper off of the ECX Ruckus 1/18th Brushed 380. And adjust it to be tighter?
Jan 07, 2014, 12:16 PM
Paul Onorato's Avatar
I believe you can remove the cover that sits over the spur and pinion gear. There are like 8 screws to take out. Then you should have access to a nut that is in-between the spur gear and drive cup and that should tighten the slipper.
Jan 08, 2014, 09:00 PM
I have tried to tighten it but I cannot get a grip in it to tighten it. It doesn't hold still at all
Jan 09, 2014, 05:58 PM
If you can't get a grip on it then you will have to disassemble the drivetrain so that you can properly access the slipper. Just go slow and keep track of how you tear down the chassis.
Jan 09, 2014, 06:16 PM
Oh. Great. I don't think I can really do that but I guess this will be interesting
Jan 09, 2014, 10:12 PM
I have the older ruckus and that is exactly what I had to do to get to the drivetrain
Jan 10, 2014, 03:30 PM
Gecko Guy
Mr. Slender Man's Avatar
take a pliers and jam it into the outdrive and tighten the nut. the tires cant move when adjusting the slipper.
Jan 11, 2014, 09:50 PM
I did it on that truck with needle nose pliers on the nut.
I just pushed the truck down on its wheels on the table to prevent it from spinning.
