This thread is privately moderated by burkefj, who may elect to delete unwanted replies.
Jan 06, 2014, 05:58 PM
burkefj's Avatar
F-106 Delta Dart RC rocket glider or pusher parkjet Kit Information
F-106 Delta Dart Kit weight RTF is 10-12 oz for the aerotech reloadable 24mm E-6, D-7, e-7 rc reloads and Estes D-11P, D12-0* and E12-0*. These kits are hand cut and fitted.I'm doing a lot of the work for you, Fuselage sides are laminated with a carbon nose reinforcing, wing spars are pre-slotted, Elevons are pre-hinged. The motor mount is pre made. The joints are pre-taped so you unfold them, apply CA+ to the joint and they are ready to be assembled...As an option the kit can include a pre-built adapter that clicks into the 24mm rocket mount and has a ply plate that allows you to mount a pusher electric motor so that you can convert from rocket to electric in a few seconds. Basic steps and instructions for download are shown below, basically the steps are gluing pieces together and taping.
For ordering or more information go to
www.dynasoarrocketry.com
Included:
Airframe pieces with carbon spars, elevons (pre-installed)
Control Horns
Nose weight
Pushrods
Motor mount
Rail buttons and screws or launch lug(your choice)
styrene strip for reinforcing
velcro for mounting rx/bec/battery
blenderm tape(for taping wires and reinforcing joints)
*(Estes motors require a small amount of epoxy to be placed in the front of the motor so that the motor is not ejected and does not damage the foam) . This is not a manufacturer approved change and is not allowed by NAR rules but is an option if you are launching in your own field.
Mar 16, 2015, 09:10 AM
burkefj's Avatar
Deleted
Apr 06, 2016, 03:26 PM
J Bergsmith's Avatar
Progress so far on the Delta Dart. This is a very quick and easy build. Should be light, and fly as good as it looks.
