Jan 02, 2014, 08:05 AM
No RTF flies like your own SB
mperaltaoz's Avatar
Build Log
P-51D Mustang 1200mm
UPDATE: this plane is a great flyer.
Maiden and subsequent flights:
Mario's P-51 Scratchbuild - Maiden Flight (3 min 15 sec)
Mario's P-51 Scratchbuild Flight No2 (1 min 45 sec)
Mario's P-51 Scratchbuild Flt No 4 (4 min 0 sec)
Hi All,
I've started a new build. This time is a P-51D Mustang.
As usual, I'm converting balsa plans to foam.
Plans: http://www.hippocketaeronautics.com/...?image_id=4939
Specs
Wingspan: 1200mm
AUW: I estimate it will be approx 1kg
Motor: D4023 850kv (https://www.hobbyking.com/hobbyking/s...arehouse_.html)
Prop: 11x7 for about 1.5-1.8 kg thrust and approx 100kph
Battery: 4S 2200mAh
ESC: 40A (50A burst)
Construction materials are XPS (extruded polystyrene), plywood and CF rods.
Construction method is ribs and skins.
A few pictures below.
Jan 02, 2014, 08:13 AM
All can fly...Launch stronger!
ttersu's Avatar
Subbed!
Jan 02, 2014, 07:33 PM
Marty Petri Sr.
mbpetri's Avatar
Great start, will be following with much interest in your progress. What thickness foam are you using?
Marty
Jan 02, 2014, 09:02 PM
mperaltaoz's Avatar
Hi Marty,
I'm using 5-6mm boards for the structural parts and 3-4mm boards for the skins (approximate measures as I cut them with my hotwire bow which is not that precise).
Jan 02, 2014, 09:08 PM
Marty Petri Sr.
mbpetri's Avatar
Well that answers another question that has been plaguing me. Here in Thailand, the material is sold as 3mm and 5mm sheets. The 5 is fairly consistent but the 3mm varies form 3.2 to 4 and even varies within the same sheet. I was wondering if they could be trued up using hotwire. hmmm Still thinking about 3mm precision ground steel pieces as guides and sand them into submission.
Marty
Jan 02, 2014, 09:57 PM
mperaltaoz's Avatar
Those sheets should do just fine. 5mm for ribs, formers, fuselage sides and bottom, and tail feathers. 3mm for skins, you can bend it easily with one of those pizza dough sticks against your tummy. No heat forming required.
Jan 03, 2014, 02:35 AM
mperaltaoz's Avatar
Nose works
Some progress on the nose.
Spinner, cowl, firewall.
Jan 03, 2014, 09:00 AM
Andres Lu
joker24458's Avatar
Looks good! Subbed.
-Andres
Jan 03, 2014, 09:40 PM
mperaltaoz's Avatar
Left wing
Ribs and skins method for wings.
Added doublers for servos and landing gear.
Jan 04, 2014, 05:40 AM
ttersu's Avatar
Are you going to put fixed or retract landings?
Jan 04, 2014, 06:02 AM
mperaltaoz's Avatar
Fixed for the time being.
I might put retracts at a later stage but I'm not a big fan of them.
Jan 04, 2014, 06:07 AM
ttersu's Avatar
Ok, Just think about removables ones then, and/or retracts supports before wings are closed...It's easier now then many times later...
Jan 04, 2014, 02:02 PM
mperaltaoz's Avatar
Yes there will be removable
Jan 04, 2014, 02:34 PM
ttersu's Avatar
Cool
Mustang is so beautful flying without legs!
Jan 08, 2014, 07:35 AM
mperaltaoz's Avatar
Spent some time last night and tonight and got the other wing done.
Starting to look like a plane.
Discussion Mustang P-51D 1200mm Balsa electric conversion junioradrover Glow to Electric Conversions 1 Aug 04, 2016 07:40 PM
Help! 1200mm P-51D mustang? disck52xm9 Electric Plane Talk 1 Jan 03, 2012 10:48 PM
