Jun 19, 2017, 11:41 AM
Modeler/ Historian
Stephen Vick's Avatar
Scorpion
USS Scorpion SSN589 in company with USS LaVallette DD 448. Both 1/96 scale Scorpion was built from the original D&E Miniatures Skipjack kit.
Sep 13, 2017, 07:30 AM
automatic dynamic dive and surface U-boat
automatic dynamic dive and surface U-boat (5 min 30 sec)
Sep 14, 2017, 10:30 PM
How did you manage to take this wonderful shot?
Sep 15, 2017, 10:37 AM
I installed a camera in the push knee of a Springer tugboat and the recovery bucket.
I had 2 transmitters.
One is for submarine and another are for Springer tugboat.
I fixed a transmitter for submarines on a half throttle and hung from a neck by a strap, and operated a transmitter for tugboats, and a tugboat was done so that it might run in parallel next to the submarine.
Sep 18, 2017, 07:32 AM
Academy 1/150 Type IXB
Started my own Academy Type IXB conversion. I'm only going with 2 channels here, rudder and throttle. I retained the automatic dive mechanism.
Made a stuffing tube for the propeller shaft. Used a 1/8" brass tube with brass grommets for bearings.
I shaved the pins off the "radar" mast pivot and bored a hole for a 1/16" aluminum shaft I placed in the tower. I also removed the deck under the tower to access the automatic dive mechanism .
Sep 20, 2017, 06:15 AM
Originally Posted by redboat219
I shaved the pins off the "radar" mast and bored a hole for a 1/16" aluminum shaft I placed in the tower. I also removed the deck under the tower to access the automatic dive mechanism .
I'm very interested.
Is the linkage made bow plane additionally from a radar mast?
Sep 20, 2017, 11:28 PM
Not sure if this is what you mean, the bow plane position are fixed.
Sep 21, 2017, 08:42 AM
Oh, I made a mistake. I thought they might be able to control the kind of diving by the strength of the thrust.
I'll get a kit of a submarine newly and try by myself.
Sep 21, 2017, 10:28 AM
Wattechighlander,
Found another Academy Type IX conversion.
From what I understand the builder
chose to go with 2 channels only
https://blogs.yahoo.co.jp/senkan8/5288656.html
Oct 11, 2017, 03:46 PM
Latitudes vs Attitudes
Bob Gaito's Avatar
Scratch built static diving 1:64 scale Gato class-fore and aft water Ballast, fiberglass hull, working dive planes, from Taubman plans.
Oct 15, 2017, 07:58 AM
I-401 Japanese SUB
DOYUSHA 1/300 scale WW2 Japanese SUB I-401
control surface : ESC for thrust motor , one servo for rudder , modified Automatic diving control system
イ401 test3.1 (4 min 50 sec)
Oct 15, 2017, 02:34 PM
tchalfant's Avatar
My Walrus on a maiden voyage.
Description:
Ran well, still a little aft heavy submerged, relatively easy fix.
Oct 15, 2017, 10:33 PM
Wattechighlander,
Very nice set up. How many degrees are yor dive planes set during surface running and how many degrees does your dive planes go up during a dive?
Oct 16, 2017, 06:17 AM
Wattechighlander,
Thank you.
Each degrees are case by case.
Basic way of thinking.
The bow plane has big angle and wide area.
The stern plane has little angle ,because screw slipstream strengthens the power.
Each plane doesn't work ,when dead slow ahead.
Oct 18, 2017, 10:45 PM
hmmmm I may have to make some stealth orders and hide them in the basement till schools done... hahah ... I didn't even know about these old motorized auto diving subs! ... I'll have to put them beside the dumas bluefish and akula I have a soft spot for too! ...
even after owning a 'proper' rc sub with a subdriver WTC ..etc ... the 'old' dynamic kits still have a definate spot in my heart.
Discussion Youtube - sub 4 sub thread - subscribe to my channel and I will sub to yours nitbeat Other Websites 13 May 05, 2017 12:09 AM
