I emailed Sig yesterday and was quoted $286.79, which is substantially cheaper than Hangar 9's new P47 razorback. The most important thing I noticed is the weight, they advertised the weight at 9.5lbs where as my H9 model is almost 13lbs. I had the FMS 1700mm 4 blade scale prop setup on my H9 P47 and wasnt impressed with it because of the weight so I took it off and went with a DLE 20. Now if this P47 does come in at 10lbs or under then the FMS setup would be perfect and I would do it in a heartbeat to run that scale 4 blade prop. If so I may be selling my H9 model and getting this one. I like the Snafu scheme better anyways. |
Thanks! Got it a two piece wing with tube setup is okay on Warbird.
Thanks again for the reply. I am back to consider. |
I did... i originally had the FMS 1700mm scale 4-blade prop and motor setup in my H9 bird but with the weight of around 13lbs it was just to heavy for it so I went gas. If i go with this seagull plane and the weight is correct and under 10lbs, then im going electric with the FMS setup.
Thanks.
If its the later part you might just consider having it in January....just saying. |
I have the Hangar 9 P-47 also.Mine is still in the box though. I took it out to check the wing alignment issues others have had. Guess what, mine has the misalignment issue too! It didn't seem as bad as others have posted, possibly a little TLC, we'll see. It went back in the box for now until I call Horizon to see what they will do, unfortunately I have had it for awhile. I really liked the look of the Seagull P-47 and placed it on back order. I have had several of their ARF's, all of them good quality in my opinion.
I see $346.36 and FMS doesnt have a big Spitfire
