Thread Tools |
This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies. |
Bluetooth battleBest stencil job of them all. A joy to fly, but the spruce isn't retaining its bend. After a solid day of banging on them, figured out the pile of bluetooth boards has at least 3 incompatible firmware versions with different AT commands. It's a matter of trying different baud rates & different AT=VERSION commands to get the version. The one installed was a lighter solder mask & ended up being an HC-06/Linvor 1.5. Power up without pairing or tying the CMD pin to 3.3V. The serial port defaults to 9600 baud. Must paste the AT commands with no linefeeds, no delays, & in caps. AT+VERSION AT+NAMEMarcy1 AT+BAUD8 The dark solder mask may be EGBT-046S. The phone retains the old device name. This is the 1st aircraft relying on hot glued electronics instead of body taped or double sided taped electronics. Hopefully the crash damage won't be worsened. |
Would that give you the right thrust angles and center point for the prop shaft? It might make construction simpler if it would work with your other requirements. Cheers, J |
could you post plans and where the centre of gravity is and the thrust line as i would like to build one. i would probaly build it using micro components but i can scale it down myself
It's an extremely cool concept... awesome practical implementation of the physics involved. Jack... are you selling / developing any marketable prototypes yet? Thanks, and if I'm completely off base please correct me. J |
yes i did not want any thing to clever and was not expecting to make it move although if i spent enough time on it and managed to write a code like that it would be cool, but i would probaly have to make it bigger so that i could put an audino on it. just so that it could go up and down in a stable hover would be fine for me even if you could not control hight. i just find it a very intresting concept that i have no understanding of thus i want so much detail on the plans.
** Sorry for hijacking your blog Jack. ** J |
sorry+1
