Thread Tools |
This thread is privately moderated by leadfeather, who may elect to delete unwanted replies. |
Leadfeather,
Reckon you could add this to the list? Build log: https://www.rcgroups.com/forums/show....php?t=2057761 Thanks Tom |
Your build has been added to the list. |
I've added MrJan's Valor V-280 to this thread. Please let me know if there are other VTOL's that should be included.
FireFLY6
It seems we have a new commercially available tri-copter tilt rotor.
http://www.birdseyeview.aero/ $474.99 for the plane $399.99 for the power pack (Motors, ESC's, Props, etc.) You buy RX, Batteries, BEC, Flight Controller, Camera(s), FPV Gear Flight time approximately 15 minutes with minimal hovering and 2 Thunder Power TP3900-3SPP25 batteries (3S, 3.9Ah each). Less than half that for hovering only. Specifications: ◦Wingspan - 60" (1524 mm) ◦Length - 37.4" (950 mm) ◦Weight - 6-7.5 lbs (2.72-3.16 kg) |
The Aurora Flight Sciences Goldeneye 50, 80, and 100 are worthy of mention in the tail sitter categories.
http://www.aurora.aero/development/goldeneye50.aspx http://www.aurora.aero/media/gallery/goldeneye80.aspx http://www.aurora.aero/media/gallery/goldeneye100.aspx |
Thanks again Ran. These are now listed in the non hobby section.
Another for the list:
Aerovel Flexrotor
Tail sitter (sort of) with single helicopter rotor http://www.aerovelco.com/Flexrotor.html
Tilting body
http://www.freewing.com/FlightVideo/Has anyone built a tilting body like shown and has been done by Scaled Composites ?
Flight videos three of them you HAVE to see !!!! http://www.freewing.com/TiltingBody/ Just need a screw jack to tilt the body, unique landing gear and keep the fuselage free from the wing. Yes, I want to build one. Any help would be appreciated. |
I built a plank style wing with independent halves like the freewing but no fuselage or center section. (two motors, two esc's, two batts, two receivers, one elevon on each side) I called it the "Inverter" because it could turn around by inverting on itself.
It needed gyros to regulate roll because in that configuration, a roll command commands a roll acceleration not the roll rate. It wasn't fun to fly so I eventually locked the halves together -- and was able to unlock them with a servo to perform the inversion maneuver ... then shelved it. If you want to build a freewing go for it, but be prepared to face more control difficulty than is obvious. |
Hi! My VTOL rcplane AL-102 TK "REGION ANGEL":
http://www.alexandrov-jets.ru/proekt...-region-angel/ |
