Dec 02, 2019, 08:38 PM
aka: Major Tom
Just figured out that I cut two polyhedral joints which is why they would not glue together. Won't make that mistake on the new wing.
Yesterday, 10:26 PM
aka: Major Tom
Well ... I tried to maiden today and it was not good. There is NO POWER to get the plane in the air. I used a 2S 850mah battery, 2805 motor and 6030 prop. I've done something really wrong cause it's not close to flying.
Thoughts? Suggestions? HELP! lol
Yesterday, 10:50 PM
Foamy and Glider fanatic
Blacky's Boy's Avatar
check your thrust angle on your motor. From past experience I can tell you that and under cambered wing will require a little bit higher of a thrust angle
I had the same issues when I build my own under cambered slow flying plane. I found that increasing the thrust angle solved this almost immediately
Today, 12:21 AM
IMO ( In My Opinion ) →
balsa or carbon's Avatar
How did it glide when you attempted to fly it ? A gentle floating descent , or dropped like a brick ? If it dropped like a brick it is likely overweight . If there's any way to lose weight , that may help .
Can your motor use a 3S battery and a larger prop ? A 3S battery will give you higher RPM's , and a larger prop will give you more thrust . If your current motor can't use 3S and a larger prop , replace it with one that can . The motors that can use a larger prop are usually lower KV .
The square nose may be blocking the prop wash coming from the small 6" prop . With an 8" or 9" prop , the prop wash will better clear the square nose . Tapering the square nose may also help .
