Dec 10, 2013, 06:28 AM
New Product
Brushless gimbal Red Epic Belt drive YAW Axis http://OFFTHEGRIDWATER.CA
The FULL KIT NOW available with Brushless Belt drive for DjI s800 & droid works Cinestar .
Red Epic 3-Axis hand held Brushless Gimbal includes heavy lift landing gear for the brushless gimbal will fit Cinestar, hoverfly, carbon core, droid works multi copters no modification. For RED Epic, Red Scarlet,free shipping by DHL/FEDEX/UPS/EMS
RED Epic Gimbal :
We have finally developed a suitable RED EIPC Brushless Gimbal, the new RED Brushless Gimbal has three major features:
1, this gimbal has been upgraded from the rack structure , the active rotation axis is more robust and more reliable.
2, the new brushless motor torque is also upgraded, it can take 3-4kg cameras, which means it can afford almost all of the cameras and larger lens combinations.
3, new tube aluminum corner fittings to create integrated structure, which makes installation fast and simple.
Delivery time: 10 days after payment Electronics may be shipped separately by EMS du to battery's
Included in the RED Epic gimbal frame kit:
Product Data:
Load Weight (Reference Value): 3.5-4kgs
Max Controlled Angle:
Pan axis: +-270°
Tilt axis: +-360°(adjustable)
Roll axis: +-55°
Net Weight without electronics: 1.98kgs Inner size: width 200mmheight 200mmlength 100-175mm(adjustable) Includes:
1 x RED Brushless gimbal Pro User
2 x iPower Gimbal Brushless Motor GBM8017-120T for red epic camera gimbal
2 x iPower Gimbal Brushless Motor GBM5108-120T
1 x lipo charger
1 x Gimbal Stand
1 x power switch battery indicator 11.1V PH-021
1 x BaseCam (AlexMos) SimpleBGC 3-axes stabilization kit
1 x Multi copter Yaw 3-axis motor cage, full LD Gear available by request heavy lift leg tips included for extra cost
3 x CW-021 500mm Servo Y Extension Wire Cable Futaba JR
1 x FS-TH9X FlySky 2.4G 9CH Radio Model Transmitter&Receiver For Airplane
2 x BY002-25C-11.1-2200 Maxforce 11.1V 2200Mah 25C Li-polymer Battery for Trex 450 etc
1 x CW-035 T-shape Adatpor/Dean Style Male W/10CM Wire 14AWG DNMLPT
1 x LC-E4 SKYRC e4 Balance Charger
1 x FV-RC701 Boscam RC701 All-in-one monitor + FPV wireless receivers + Diversity
1 x FV-TS5833 Boscam Thunderbolt2000 2000mW 5.8GHz Video AV Audio Video Transmitter Sender FPV
Dec 10, 2013, 07:04 AM
This gimbal with 8017 motors is allready advertising that it's capable of handling RED camera. So why do we need belt driven YAW axis?
Dec 10, 2013, 07:29 AM
http://offthegridwater.ca
hi Brushless Motor belt drive on the YAW removes unwanted rotation on YAW axis during normal operation, smooth easy rotation threw RC transmitter. It hard to remove all the jitter to twitching from YAW axis in direct Brushless drive.
Dec 10, 2013, 07:34 AM
Brushless Motor belt dive is nice addition to or line up.
Dec 10, 2013, 03:20 PM
So it make no sense advertising this gimbal with 8017 directdrive motor on YAW and telling it's capable to stabilize red camera without jitter and twitching yaw axis?
Dec 11, 2013, 05:33 AM
Yes no jitter more power to the yaw and quick release from gimbal are the features.
Dec 11, 2013, 08:10 AM
HAND HELD IS DIFFERENT! You are steadying the yaw by hand so no jitter in your hand.
Dec 11, 2013, 03:11 PM
There's no need for CAPS LOCK.
Ok. Let's address next problemS.
You are aware that because of 'roller track system' you can't properly balance roll and yaw axis on this gimbal?
You can't move rod that roll motor is attached to because whole rod must be always in perfect middle or roller track will fall out.
Similar thing with balancing yaw axis. With this gimbal, you can't balance yaw axis, because it always has to be in the same distance or roller track will fall out of its bearings...
Dec 12, 2013, 06:48 AM
yes the roll rail is adjustable and made to balance the RedEpic makes it easy to ballance
Dec 12, 2013, 06:50 AM
yes the roll rail is adjustable and made to balance the RedEpic makes it easy to balance. the roll rail is removable and adjust up to 25mm
Dec 12, 2013, 07:30 AM
You obviously have no idea what are you taking about and trying to resell...
Roll and pan can't be adjusted with this gimbal, because of slider track, which doesn't allow moving pan center to balance that axis, and roll also...
Why would you need to remove one of major selling points in advertising of this gimbal?
If it has no use of rail slider, why is there?
Dec 12, 2013, 07:56 AM
not reseller I am the designer of this gimbal! You have no Idea what your taking about! works Verry well best Pro gimbal on the market for RedEpic
Dec 12, 2013, 08:08 AM
balances Yaw and roll load baring as well .
non Red
One more RedEpic gimbal ready for delivery (0 min 28 sec)
Red Epic
(2 min 14 sec)
