Dec 05, 2013, 03:33 AM
Ron_RC
RC Flying Saucer UFOs
Hi all, If you have a UFO you've built, it would be nice to see it and know the specs for it. I'm trying to get people to call in a sighting here in Washington state with my UFO.. Who knows, I may have already gotten people to call. I incited one man to drive into our neighborhood and cuss me out and tell me to stop that #*%!. Ha ha! All the best and Happy flying!
UFO Space Alien Flying Saucer Original (4 min 41 sec)
Dec 06, 2013, 09:08 PM
Multi rotors=No Paycheck left
SDSURFnGLIDE's Avatar
that's pretty rad dude!! ive been wanting to make one myself...I have enough parts laying around too for this...just haven't gotten around for it.
What material did you use for the body? FC? lights? light controller?? love the little alien dude. I would probably set mine up for FPV too!!
Dec 10, 2013, 05:22 PM
Ron_RC
SDSURFnGLIDE,
For the body it's self, I used some 1/2" styrofoam insullation to make the bottom of the fuselage, the prop ducts, and he skirt that goes around the bottom, and I used 3mm depron to sheet the top.
For the booms, I used 1/2" birch square stock.
Lights: 9 mode multicolor LED from HobbyKing on my flaps switch for on and off.
For navigation lights I had non interrupted power from the 3S battery via an adapter with a JST plug. From that I used strips of three LEDs of Red (port / left side), Green (starboard / right side), Blue (fore / front), and Yellow (aft / back).
For the bottom, I used a white led strip around a circle facing out to a beveled piece of foam to bounce the light down for a tractor beam.
Propulsion system is:
an OrangeRX 6 channel receiver,
KK2 board flashed with v1.5 in the X configuration with the gear switch for autolevel,
4 - 25A HK SS ESCs flashed with SimonK,
4 - E-max 1534kv motors from HobbyKing (FC 28-12 1534kv),
4 - 3mm prop savers,
4 - GWS style 8x4 props with 3mm hole.
For paint, I used a foam safe silver (some that say foam safe will still eat the foam so test on scrap first) and foam safe flat black.
If I can finish other projects and get back on the template for this, my buddy will cut them on his laser cutter and we will sell the bodies with the basswood and 1/8" ply pieces to hold it together.
However, the prop ducts on the production model will only be 7" due to the table size of the laser so the motors will need to be FC 28-05 2840kv and 6x3 3blade GWS props.
I ran this setup on the first rendition with an i86 controller and it had more power than the 8x4 props but a shorter flight time but, it sounded Awesome!
Here is a poor quality video of the UFO with the original setup.
RC UFO Flying Saucer with Lights (4 min 52 sec)
Dec 10, 2013, 07:40 PM
cool...thanks for the run down...i have a few sets of different sized motors sitting around..2212 1250kv...2814 11 1000kv...and 2814 11 750kv...couple fc's too...have a kk2.0 or mw flip and a mwpro with gps...haha...but to keep it simple...id probably stick with the kk2
Dec 11, 2013, 11:42 PM
7 foot floater
rudyauction509's Avatar
I made it into the newspaper here in spokane a couple months ago with my 7 foot plane covered in LEDs because a bunch of people around the field where I fly thought it was a UFO. A nice reporter and photographer came and wrote an article about me and I gave them a demo flight. Now most of the people there know me and some stop by when I'm flying. I'm planning a quadcopter build with short range FPV equipment, I might put some lights on it and fly around the neighborhood and see what happens.
http://www.spokesman.com/stories/201...cefully-above/
Feb 04, 2014, 03:14 AM
Ron_RC
Ha ha ha! Rudy, that is awesome. I've had people drop by thinking they had seen a real flying saucer UFO but never a news writeup. That is great!
My UFO sat in my garage for a while as an unfinished project, then I decided to put some motors in it and give it a go.
Here is what it looked like when I finally got it airborne in the garage.
RC UFO Flying Saucer w Carbon Fiber Xcopter (6 min 1 sec)
Feb 04, 2014, 03:20 AM
Ron_RC
That sounds like a great idea going with the KK2. I started out with an i86 and found out quickly that it needed more to keep it steady in the air. When I put the KK2 board in it, it responded nicely and now I only fly this in autolevel. Every time I try to go into manual mode to do flips, I eventually crash. It has a hard time recovering after a flip and needs plenty of elevation. All the best and Happy flying!
May 27, 2015, 11:27 AM
Ron_RC
My newest UFO with a tractor beam and build photos and a crash.
UFO Flying Saucer Tractor Beam and Build Photos (3 min 26 sec)
May 27, 2015, 11:30 AM
Ron_RC
My newest UFO after repairs (a little CA glue but no structorial damage) and a new ESC with an improved tractor beam (1000lm). This time it's beaming down a hexapod drone to take over the world! Ha ha!
UFO Flying Saucer with Improved Tractor Beam - Ron_RC Episode 2 (3 min 32 sec)
May 27, 2015, 11:31 AM
Ron_RC
Delta wing UFO.
Is it a UFO!?! (3 min 41 sec)
May 29, 2015, 02:06 PM
Ron_RC
Seems someone may have been watching my videos.. Ha ha! Cheerson has came out with a micro flying saucer and when I saw it, I had to get one. They are around $30 from several venders and have a 500mAh 1S battery! Wow!
So, when it came in the mail, I had to get some video.. here goes:
Cheerson CX-31 micro UFO Ron_RC Episonde 3 (4 min 32 sec)
Dec 30, 2018, 01:46 AM
Ron_RC
Well, I've done it again.. I've built another one.
RC UFO Flying Saucer Sighting with Tractor Beam (3 min 27 sec)
Jun 05, 2019, 04:19 AM
Ron_RC
Here is another flight of the 32" UFO sighted on 20 Apr 2019
UFO Flying Saucer sighting 20 Apr 2019 (5 min 12 sec)
Jun 10, 2019, 09:17 AM
Ron_RC
RC UFO Flying Saucer beams up my wife and replaced her with another alien life form.. Ha ha!
UFO Flying Saucer Beams Up My Wife! (4 min 18 sec)
Discussion FUN UFO Flying Saucer... gpw Foamies (Scratchbuilt) 209 Jun 11, 2019 05:46 AM
