Dec 19, 2013, 01:06 PM
Plane Destroyer / Life Enjoyer
airbagit13's Avatar
Same. Where do you fly in Miami? I fly in Kendall.
Dec 19, 2013, 03:55 PM
Mobius Cables... I got em'
chanyote66's Avatar
hows the reviews going? anyone have this thing running with MFD AP?
Dec 19, 2013, 04:13 PM
Still waiting for mine to arrive. Has been sitting in Shenzen since 12/13 ...
Dec 19, 2013, 04:19 PM
FPV Pilot
blueprint's Avatar
I got the servos in the wings.... im about to glue the two fuselage halves together and get her ready.
Im undecided whether i'll run the MFD....
Dec 19, 2013, 07:39 PM
ls1elite's Avatar
kendall too infront of the babtist hospital , near chrome ave and sometimes in key biscane. hit me up we should gather up and fly, two of my cousins also fly with me all the time.
Dec 19, 2013, 07:40 PM
ls1elite's Avatar
fpv model shipped mines already,, that was fast. im thinking on running hitec metal gears.. idk what prop tho..
Dec 19, 2013, 08:07 PM
FPV Pilot
blueprint's Avatar
Im using hs65hb all around. Metal gear not necessary.
Dec 19, 2013, 08:51 PM
ls1elite's Avatar
what power system are you using ? running 4s or 3s ?
Dec 19, 2013, 09:27 PM
chanyote66's Avatar
I think if I get one of these ill throw my ARC 1500kv inrunner in it on 4s with an 8x6 prop it would move along nicely!
Chris
Dec 20, 2013, 12:29 AM
FPV Pilot
blueprint's Avatar
4s on a 2216 1100kv tiger motor.
Dec 20, 2013, 12:46 AM
I will run a Turnigy 2836 1100kv with 5000mAh 3S on it.
Based on calc, it says about 0.74:1 thrust plus about 47min flight time at 46mph.. not bad.
Dec 20, 2013, 08:06 AM
USA: LakeGeorge, New York
What size props are you guys using w/your intended motors?
Latest blog entry: My FAVORITE FPV CockPits'!!!!
Dec 20, 2013, 08:33 AM
FPV Pilot
blueprint's Avatar
Graupner 8x5 or 9x5.
Dec 20, 2013, 02:45 PM
Yeah 9x5, 9x4.5 depending.
Dec 21, 2013, 08:33 PM
I just did a maiden flight using a 5000 3S on a 1500kv motor. Only had a 7x5" prop handy but still got an easy 20 min flight with plenty of varied throttle. This is a FUN plane! It flies more like a wing, on rails and turns and loops so quick. It was a bit gusty but it didn't seem to get thrown around much. Only issue I can foresee is how fast it glides in for landing so you need plenty of space unlike the Bixler. It did glide pretty nice once I moved the cg back behind the main spar - the cg stickers on the spar were wrong. I'll probably move cg back a bit further yet. And I also had to enable the esc brake for better glide, though leaving the prop spinning might be one way of slowing the bird down for landing.
I took some ground footage so will post some up when I get time.
