This thread is privately moderated by Manudepron, who may elect to delete unwanted replies.
Nov 23, 2013, 11:48 AM
Manudepron's Avatar
30 cm wingspan indoor flying wing
Micro indoor 30 cm wing
I found on the net some years ago a basic plan for an A4 size flying wing. I kept it on my HD disk just in case...
I build one to celebrate the opening of our indoor season and I am pleased. Some adaptations but basic scheme is kept: sory for the original designer I don't find anymore.
No carbon strip to reinforce but under the wing 2 strips of fiber reinforced tape.
All 3 mm depron except fuse out of a 6 mm EPP scrap.
0.5 mm piano wire pushrods
1.7 grs servos, a micro receiver and a micro brushed ESC from HK.
Mustang motor on a 4 x 4 gws prop.
31.1 grs with a s 160 mah lipo
Flies nicely but more like a butterfly than a jet: lacking of vertical power but I will try to boost it. First test with a 3 x 3 prop, changed for a 4 x 4 gws slightly cut but will try to change again for a better prop...
Video:
A 4 Delta rc wing (0 min 42 sec)
