Naze32 Base Flight ? Naze32 Clean Flight ? CC3D ? |
Hi everyone,
I recently bought QAV250 with AfroNaze32 FunFly and Taranis X9D plus, with FrSky X8R. I followed all the instruction i could find and watched hours of videos about setting up a new model, arming the motors etc... My quad is still sitting on my table, not willing to fly ![]() How can i check if my X8R receiver is working? I ask this because i start my motors in Clean Flight configurator software on a motors tab, get the readings, all looks fine, as well as other readings from Naze32, it just doesn't react on any command from Taranis. Can anyone help, please? P.S. I'm a n00b in RC an open TX. |
Also, look at BMSWeb's youtube channel for a 3-part video on setting up the FrSky/Naze combo. |
When using the Setup Wizzard, did you select the QAV250 option as a starting point? I'm assuming you are on 3S and 5x3 props? Which 1806 motors are you using? Emax or DYS or some other? Also, what ESC's? This info will help us help you.
cc3d Lumenier 1806-14 2300kv Lumenier 12amp ESCs with SimonK firmware 3s 1300 batts 5 x 3 props iv set up using qav250 setup from wizard but quad keeps blowing out in turns and under high throttle inputs. Iv also set up a qav400 from the wizard and its rock solid. thanks |
I hope this helps. |
Anyone know where i can find the top plate for the Gopro like the one Charpu is using? Also the arm extenders
