Jun 01, 2018, 05:56 AM
nopkorn's Avatar
Originally Posted by mojtaba.hdpr
hi ben
what happen for your soft ?
Hi flipflap,
Hope to be back soon. Because my friend just finished assembling. But he can not continue.
Jun 01, 2018, 08:58 AM
mojtaba.hdpr's Avatar
thanks nopkorn
Jun 01, 2018, 09:42 AM
Hi flipflap...
me too! I just got a new FTDI
greetings
Jun 01, 2018, 11:18 AM
Hi does anyone know how to change the baudrate of Bluetooth module on Sami board, does it must be changed before soldering? I can't send an AT command by USB in AT Mode.
Jun 01, 2018, 03:04 PM
And voilą, the beta is extended until December !
Jun 01, 2018, 03:21 PM
Merci Flipflap
Jun 01, 2018, 03:35 PM
thanks
Jun 01, 2018, 03:37 PM
it seems that there is a bug at start
Jun 01, 2018, 04:24 PM
Build more, websurf less
FlyingW's Avatar
That is probably because you have bluetooth active on the PC. Try turning off BT and see if the Control Center comes up normally.
Jun 01, 2018, 04:25 PM
FlyingW's Avatar
Thanks flipflap. Anything new in version 58?
Jun 01, 2018, 04:53 PM
That's exactly the same one, but I've got here a version with PWM servo output for the 100mW modules. Then the failsafe bug to solve.
Jun 01, 2018, 05:12 PM
Hi everyone,
For the new bee board, I want to share with you other cheaper links for buying the components,
Capacitor 0805 0.1 uF https://www.ebay.com/itm/50pcs-0805-...53.m1438.l2649
Capacitor 3528 100 uF https://www.ebay.com/itm/5pcs-Tantal...53.m1438.l2649
Capacitor 0805 10 uF https://www.ebay.com/itm/10PCS-6-3V-...53.m1438.l2649
All 0805 resistances https://www.ebay.com/itm/0805-SMD-Ch...53.m1438.l2649
LED 0805 https://www.ebay.com/itm/50-pcs-SMD-...UAAOSwv0tVDA3q
SMA Female for soldering https://www.ebay.com/itm/SMA-Female-...AmqtVP2tlBeBFg
And as a personal recommendation Ebay is better for buying tiny and cheap things like electronic components. Aliexpress is better for bigger things which a normal cost of more than one dollar.
Jun 01, 2018, 06:24 PM
nopkorn's Avatar
Thank you so much.
Jun 01, 2018, 09:58 PM
nopkorn's Avatar
Originally Posted by gcp900
Hi everyone,
Thank you. ^_^
Jun 01, 2018, 11:45 PM
Hi Nopkorn,
Did you cut the edges of the Pro mini ? I only could find ones with through holes
Ro
