Nov 06, 2017, 04:48 AM
Originally Posted by flipflap
It's compatible, just use the same pinout as other modules.
thank you
Nov 06, 2017, 09:17 AM
Build more, websurf less
FlyingW's Avatar
Almost any LED will work, however I've provided a link to "high luminosity" blue LEDs that work pretty well. For other LED types it may be better to use a lower resistance, but that will go through some experimentation.
(1) Ok, please give me some numbers. I found some that are 2.2v as some spec said to use, but I cannot find blue ones that are less than 3.5v. There are hundreds of choices. I greatly appreciate some actual specifications that I can use to order some.
(2) Also, on the Monkey board build instructions there is a resistor near the upper left corner of the transmitter module that is shows as "R9 Resistor Value TBC". What does that mean?
Paul
Nov 06, 2017, 01:42 PM
Paul
I am using 3v leds in the spongeboard, green and blue.
Nov 06, 2017, 04:28 PM
Quick question on the Tx connections. I have the module connected to my Tx and powered by it. Now I need to connect it to an FTDI with VCC and GND connected? Can this FTDI be 5V with an Orange Rx 1W module?
Nov 06, 2017, 04:41 PM
Normally not, because the Orange 1W does actually works at 3.3V.
You can however connect them via 1k resistors on RX and TX lines and won't take any risk, or try to connect it directly and cross your fingers.
Nov 06, 2017, 04:52 PM
Thanks. And again making sure, I connect the FTDI 3.3V to the module while it is powered from the Tx? Won't it create a short?
Nov 06, 2017, 07:13 PM
FlyingW's Avatar
Will this LED work?
It is blue, with a voltage spec of 3.4 volts:
https://www.sparkfun.com/products/11372
This one red, but has a voltage spec of 2.0 volts:
https://www.sparkfun.com/products/9590
Does it matter that they have different voltages?
Is one voltage better that another?
Which is best for ULRS mini boards?
3mm or 5mm?
Paul
Nov 06, 2017, 07:43 PM
What i use. LEDhttps://www.amazon.com/gp/aw/d/B004U...?ie=UTF8&psc=1
Nov 06, 2017, 07:48 PM
Fwiw i really think you're over thinking the leds. Any of those should work fine. I used blue and green cause i have an ftdi chip that uses those colors and it really gets your attention.
Nov 06, 2017, 08:08 PM
FlyingW's Avatar
Thanks KaudiTT,
I am overwhelmed by selecting these parts from the thousands available on electronics parts websites. Giving me the link to ones you know work was very humane.
Does the Sponge board have the capability to press a button to save the failsafe servo positions?
Nov 06, 2017, 08:34 PM
I know you're frustrated and have been working at ulrs a little while but i think it's definitely worth the effort.
It doesn't have a place on the board for it but you will only need the button on the transmitter. I am using a wolfbox as my tx and spongeboards as rx. I also use the gcs failsafe in mission planner to be safe, especially since i am relaying the control signal through an antenna tracker.
Nov 06, 2017, 08:54 PM
FlyingW's Avatar
What kind of capacitors: Ceramic multi-layer, monolithic, ceramic disk, etc.?
I want the failsafe feature:
Flipflap, which ULRS mini boards support the failsafe button-push feature?
and,
Does the failsafe button push feature work with anything but a transmitter with 16 channels?
Thanks.
Paul
Nov 06, 2017, 10:29 PM
All boards do support the failsafe button and it works with any number of channels.
For the LEDs I'm using the blue ones but can only provide the link to my French provider (which is already on the site). Any other LED will work, but may require a different resistor to have a good luminosity (will depend on their color and precise type). 5 or 3 mm is a personal preference, I like to smaller ones. There are even larger LEDs.
The voltage of the LEDs isn't a critical factor : the important thing is the current that goes through them, and is controlled by the resistor. That's the adjustment factor.
Nov 07, 2017, 08:42 AM
FlyingW's Avatar
flipflap,
Failsafe did not work with several sets of my Orange 1W modules that performed all other functions. Note that all of the HobbyKing hardware eventually failed on the bench and I was lucky to never make it into the air with it installed.
At the time we discussed trying the failsafe button technique with a transmitter that sends 16 channels instead of the eight that my Futaba transmitter sends. Since I did not have a 16-channel transmitter, we settled on the work-around of using the GCS_failsafe to trigger a RTL.
In my opinion the GCS_failsafe work-around is good enough for a test flight, but with that configuration we lose the option to continue with a mission despite a failsafe condition.
I'm putting together a list of parts for the Monkey Board with links to vendors. I hope to get feedback about better choices for parts.
Paul
Nov 07, 2017, 08:49 AM
FlyingW's Avatar
Here is my parts list work in progress. I still need a buzzer reference.
As of 7 November this is only a draft - do not buy based on this list yet!
I will update, correct and or improve it based on feedback I get from those more experienced.
Paul
Buzzer = ?
Capacitors, Qty = 8
http://www.newark.com/kemet/ck05bx10...x7r/dp/87F4662
5v regulator, Qty = 2, TSR 1-2450
http://www.newark.com/tracopower/tsr...l-1/dp/08R5932
90 degree SMA connector, qty =2
http://www.newark.com/amphenol-rf/13...ohm/dp/99H5025
LEDs,
https://www.amazon.com/microtivity-I...a_aw_oh_bia_dp
Resistors, 1/4 watt:
https://www.amazon.com/dp/B00WE1FQ8Y...detail_3?psc=1
Headers
https://www.amazon.com/Ltvystore-Bre...der+assortment
Monkey Boards:
http://dirtypcbs.com/store/designer/…7/ulrs-mini-tx
http://dirtypcbs.com/store/designer/…rx-cutdown-zip
433 module, qty = 2
https://www.ebay.com/itm/RFM23BP-433....c100011.m1850
Arduino Module, Qty = 2
https://www.adafruit.com/product/237...CAAEgItJ_D_BwE
