2. With APM/Pixhawk connected there is a Status button near com port 3. Yak-54 and JNJO have had success with telemetry not sure what radio they use (should work the same for any open-tx radio) |
I'm fairly certain I stumbled on quite a few posts of people having this, or similar, up and running on 9X:s while I was working on this. Just holler if you need any support. |
You only need a seriall invertor and a telemetry cable from that to the futaba port of the 9xr. Check the 9xr pro for more information. I have got this setup. http://m.ebay.com/itm/251103811631?_mwBanner=1 https://www.hobbyking.com/hobbyking/s...r_9XR_Pro.html No teensy, no flashing (except the 9xr itself) but just plug and play. |
Whats your opinion of the two systems? |
For info, I just updated my own repo to include a rc1 version of a working ULRS solution (with RSSI, polling etc) and have documented this in the wiki in my repo - note that my repo is the test/dev repo, and once testing is successful, this will be merged into the main Clooney82 repo with a v1.7 release version. Test/Dev Repo (containing ULRS support): https://github.com/athertop/MavLink_FrSkySPort Wiki also has some info regarding ULRS here: https://github.com/athertop/MavLink_...te-LRS-support Current Master Repo (no ULRS support yet): https://github.com/Clooney82/MavLink_FrSkySPort |
and telemetry dont work. No mavlink data |
Sorry guys that i am asking too much about simple things for a working setup.
Currently have a problem with Wolfbox TX module, It has no lights on with 3.3V and 5V inputs. It has no modification and always used with an antenna on it. It is gone when a RCmilec src771 antenna on it. And having this error while flashing through ULRS control center. |
Reason: update
I had a chat with some people of banggood and here is the answer I got from their supplier. To upgrade wolfbox TX to 1W (or close to), 1 resistor have to be changed. R10 is a 39k resistor, if it is replace by a 47k the voltage will be higher, close to 5v. Any feeling about that ? |
By the way, They have changed its title as 500mW Wolfbox 500mW 433MHz UHF Transmitter Tx & 100mW Receiver Rx |
It was on the radio with 1W upgraded orangeRx as RX when wolfbox is gone.
But then flashing performed with only FTDi cable on 3.3V jumper. Now i will try flashing when it is powered by radio too. --- Tested, still same even if i try flashing with radio power on. |
Reason: update:
