Nov 09, 2013, 12:10 AM
Arduino Lipo Cell Monitor
Hey everyone,
Wondering if there is any interest in me documenting a simple 4s LiPo Cell Monitor on the Arduino platform while I am making one?
I have searched for a while and could not find anything quickly that would show me what was required so if there is interest, I will document this here so that others can refer to this and create their own LiPo monitoring things.
Here is the basic schematic that I have come up with and values of resistors to create appropriate voltage dividers for the Arduino.
Excuse the poor layout skills in Fritzing - first time using this rather than hand scrawl attachments
Nov 09, 2013, 03:14 AM
Stuart
srnet's Avatar
I am no expert on ATMEGAs, but the circuit just does not look right.
You have the A0 pin connected to 14.4V, its through a current limit resistor, but the input clamp diodes normally found on Micros will limit the A0 pin voltage to around 5.3V.
Nov 09, 2013, 07:05 AM
That MCU also only has a 10 bit single ended ADC. You might need something a little better depending on the resolution you're looking for.
Nov 09, 2013, 06:15 PM
Dave the Rave
dmccormick001's Avatar
If you're going to use this as an "on-board" monitor, you'll need to use a smaller MCU. The 28 pins is a bit of overkill, and will make it much bigger and heavier than it really needs to be, don't you think?
Nov 09, 2013, 11:06 PM
I've put this together as a basic proof of concept - so far the testing has been promising.
I don't need terribly great accuracy with this one - I am within 0.05v of the cell voltage (only to 2 decimal places) and this is good enough for what I want it to do - determine voltages and low cutoff.
I am finding though because of the accuracy it is jumping a fair bit - so I need to either average out the values or mode the values to get a stable number.
This is actually going to be built onto a Leonardo and have a lot of other functions for a robot I am working on - I wanted to build it on a sacrificial Nano board first, to see that it does work. The other thing I will add to this is a poor person's coulomb counter - I know there are chips etc that do this, but all I want is an approximate usage of current so I will simply add a current monitor to this and poll this intermittently to get usage stats.
Nov 09, 2013, 11:10 PM
With the A0 pin, the input to that ends up being at 4.77v with 18v input, due to the voltage divider with the resistors.
I know I am not using the full range of the ADC as I could, I can use op-amps to get a more accurate range and so forth, but I am just after something simple at this stage which can give reasonable single decimal point accuracy for cutoff and monitoring.
I may re-visit this and make it more accurate in the future depending if I need this level of accuracy, but presently I feel that this should be ok for what I am looking for.
Nov 10, 2013, 01:30 AM
Stuart
srnet's Avatar
You could form a voltage divider, with the 130K and 47K I presume you mean, but that is not how you have shown the resistors are connected on the circuit diagram. They must be wired some other way.
Nov 10, 2013, 01:55 AM
After a bit more tinkering with code, this is pretty much final of what I wanted to achieve from this.
I will alter the code more later, but this will be specific to the platform I am interfacing with.
Code:
#define battPin0 A3    // select the input pins for the batteries
#define battPin1 A2
#define battPin2 A1
#define battPin3 A0
float battWeighting = 0.1; // define a weighting to apply to our exponential moving average calculation for battery
int abattValue0 = 0; // variable to store average value (exponential moving average) calculation
int abattValue1 = 0;
int abattValue2 = 0;
int abattValue3 = 0;
float Cell1 = 0.00; // variable to store actual cell voltages
float Cell2 = 0.00;
float Cell3 = 0.00;
float Cell4 = 0.00;
float adcVolt = 0.0048680351906158 ; // one point on the ADC equals this many volts
void setup() {
  Serial.begin(115200);
  // Read the battery voltage values and set up the averaging
  // require 50 reads to initialise correct ewv.
  for (int i=0; i<50; i++){
    getBattVolts();
void loop() {
  // basic get and show voltages
  getBattVolts();
  showBattVolts();
  delay(500);
void getBattVolts() {
  // read the value from the sensor:
  abattValue0 = (analogRead(battPin0) * battWeighting) + (abattValue0 * (1-battWeighting));
  abattValue1 = (analogRead(battPin1) * battWeighting) + (abattValue1 * (1-battWeighting));
  abattValue2 = (analogRead(battPin2) * battWeighting) + (abattValue2 * (1-battWeighting));
  abattValue3 = (analogRead(battPin3) * battWeighting) + (abattValue3 * (1-battWeighting));
  // convert these values to cell voltages
  Cell1 = (adcVolt * abattValue0 * 1) ;
  Cell2 = (adcVolt * abattValue1 * 1.8298)-Cell1;
  Cell3 = (adcVolt * abattValue2 * 2.6078)-Cell2-Cell1;
  Cell4 = (adcVolt * abattValue3 * 3.7659)-Cell3-Cell2-Cell1;
void showBattVolts() {
  Serial.print (Cell1);
  Serial.print ("V. " );
  Serial.print (Cell2);
  Serial.print ("V. ");
  Serial.print (Cell3);
  Serial.print (Cell4);
  Serial.print ("V. Total = " );
  Serial.println (Cell1+Cell2+Cell3+Cell4);
Nov 10, 2013, 02:04 AM
Hmm, I am looking again at this and I do think this is right...
I have built it according to the schematic and it seems to be recording the right values and voltages to the A0 pin and converting it to a real voltage.
I've double checked against an online calculator and got the voltage at 14.4v that would go to A0 as shown.
Nov 10, 2013, 02:09 AM
I forgot to include the boring output in case someone doesn't quite get what it is outputting.
(one of the cells seems to be recovering after turning off the pc that this is currently attached to lol)
Nov 10, 2013, 03:14 AM
Stuart
srnet's Avatar
Nope, look again at what you have drawn.
For the voltage divider to work, R5 should be connected between A0 and ground.
You have R5 connected to +14.4V where it does nothing apart from add a small load to the battery.
Nov 10, 2013, 08:50 AM
Dave the Rave
I think this is more like what you want.....
Nov 10, 2013, 09:17 AM
there both the same...just latter looks better.
And guessing when he hooked up the circuit for real was like second post.
Nov 10, 2013, 12:40 PM
Stuart
srnet's Avatar
Indeed.
The other point is that using fixed value resistors in this type of circuit can be a very bad idea.
We dont know what tolerance of resistors are being used, but the errors are accumulative as you go from the bottom Lipo to the top because of the way the maths are done.
Even with 1% resistors, the voltage error for the top (4th) Lipo could be close to 0.2V which for Lipo balancing is way too much.
Nov 10, 2013, 12:46 PM
Indeed.
If you're referring to dmcormick's drawing,I don't think that's correct. You could completely remove all the resistors except the ones on the A0 input and the A0 input voltage wouldn't change.
