This thread is privately moderated by smoothvirus, who may elect to delete unwanted replies.
Oct 31, 2013, 09:51 AM
smoothvirus's Avatar
Build Log
Finwing Penguin FPV
Well this is going to be a bit of change in direction for me. I have been planning on flying my Skywalker X8 as my first fixed wing FPV platform but now that the airframe is all put together it's apparent to me that I will need to build a launcher for it. I still want to fly my X8 but I came to the conclusion that I wanted to start out with something a little more simple that would be easier to setup, and then move to the X8.
So I went out and pulled the trigger on a Finwing Penguin from RMRC. The box just arrived last night, so I'm still doing research and putting my notes together. I will update this post as the build continues. I am going to get started right away as I want this to be a fast build.
Parts List:
Penguin V2 ARF with M2815 Motor and 60A ESC w/Switchmode BEC
http://www.readymaderc.com/store/ind...oducts_id=1072
5.8ghz 600mw video transmitter
http://www.futurehobbies.com/details...smitter-5-8ghz
Blue Beam antenna set
http://www.futurehobbies.com/details...blue-beam-whip
custom decals
http://www.stickeryou.com/2
EzUHF
http://www.readymaderc.com/store/ind...roducts_id=927
RVOSD5
http://www.rangevideo.com/index.php/...n-display.html
RVOSD Airspeed Kit
http://www.rangevideo.com/index.php/...speed-kit.html
GPS extension cable
http://www.rangevideo.com/index.php/...ion-cable.html
SONY Super HAD CCD II 600TVL D-WDR DNR Mini Board Camera
http://www.securitycamera2000.com/pr...a-DIY-FPV.html
Pan/Tilt Basic Kit
http://www.readymaderc.com/store/ind...roducts_id=280
Hitec HS-82MG Servo (elevator)
http://www.servocity.com/html/hs-82mg_servo.html
Hitec HS-55 Servo (rudder)
http://www.servocity.com/html/hs-55_sub-micro.html
Scotch Extreme Tape
http://www.staples.com/Scotch-Extrem...product_448960
Ground Station:
Fatshark Dominators
https://www.hobbyking.com/hobbyking/s...dProduct=19445
Fatshark 5.8ghz receiver
http://www.futurehobbies.com/details...eceiver-module
5.8 Ghz Uno receiver
http://www.readymaderc.com/store/ind...roducts_id=877
5.8 GHz HELIAXIAL58 (5645-5945 MHz) RCHP 12dBic Helical Antenna
http://www.readymaderc.com/store/ind...oducts_id=1026
RVOSD Antenna Tracker
http://www.rangevideo.com/index.php/...a-tracker.html
Antenna Pan/Tilt for EagleEyes Antenna Tracker
http://www.readymaderc.com/store/ind...products_id=96
Reference:
RCGroups Thread
https://www.rcgroups.com/forums/show....php?t=1684618
FPVLAB Thread
http://fpvlab.com/forums/showthread....eadyMadeRC.com
Prop Comparison for the Penguin
http://www.itsqv.com/QVW/index.php?t...mparison_-_9x6
Mark's Build Thread
http://www.itsqv.com/QVW/index.php?t...by_FPV_Penguin
ToysRMe Build Thread
http://fpvlab.com/forums/showthread....g-Penguin-mods
Basement RC Build Thread
http://www.basement-rc.com/forums/in...p?topic=1823.0
GroundStation TV Build Thread
http://www.groundstationtv.com/Groun...uin_Build.html
PWRCF Build Thread
http://pwrcfs.com/forum/showthread.p...-Penguin-plane
FPV Layout Thread
http://fpvlab.com/forums/showthread....-Hobby-Penquin
Paintz2007 Build Thread
http://fpvlab.com/forums/showthread....ild-Paintz2007
JimT Build Thread
https://www.rcgroups.com/forums/show...5#post27652058
nakelp86 build thread
https://www.rcgroups.com/forums/show....php?t=1750236
Nov 03, 2013, 01:35 PM
The build!
Nov 04, 2013, 11:22 AM
scottieusa's Avatar
Mine is already built and I've been flying it for almost a year now. Love the way it flies even after two crashes and breaking it in half. I subscribed to this thread in case I decide to build another one. Looking forward to tracking your progress. Good luck
Nov 11, 2013, 04:58 PM
Thanks scottieusa! Just completed the maiden, flying LOS to test everything out before I put all my FPV gear in there. Had two successful flights, photos and videos coming very soon.
Nov 11, 2013, 06:11 PM
The Maiden Flight
I decided to fly the maiden flight LOS without putting my expensive FPV gear in the plane. So I just put a Spektrum receiver in the plane, copied the model parameters from my Sig Kadet over to the Penguin on my JR 11x, and flew it. Best to start simple and make sure she flies right before putting a complex OSD/Autopilot in.
Winds were out of the south at 5mph gusting to 20mph or so. The crosswinds at my test location made takeoffs and landings a bit challenging. I did two flights, the first was a hand launch with the canopy on, and the second was a ROG takeoff with the canopy removed. She needs a bit of rudder to make the turns even with the canopy off but flies really well. There is a lot of lift from that undercambered wing!
Everything went really well, the only issue we had was losing the video from the second flight where I made a much better landing. One the first flight a gust of wind hit right as I was about to flare knocking me off course. Fortunately I had an entire soccer field to land on.
Here's the video from the first flight.
Maiden Flight of the Finwing Penguin (6 min 53 sec)
Dec 05, 2013, 05:54 AM
NCFR !!!
JRjoe's Avatar
Getting ready to build mine soon. Lots of good info here...Thanks
Dec 14, 2013, 11:10 PM
This was the best flight I've had so far. This was a test flight to try out RTH on the RVOSD. After I got it working I tried ranging out a little bit with FrSky 2.4.
RVOSD5 Return To Home Test (11 min 37 sec)
After I made this flight I tried to fly out for 1 mile on the FrSky but I only made it 4500 feet or so before I lost the link. Sadly my DVR and keychain cam messed up so I don't have good video of that flight.
Next step is setting up EzUHF.
Dec 26, 2013, 10:38 PM
Disaster Waiting To Happen
Gonna be starting my Penguin build here in the next few days. Thanks for taking the time for posting all this info.
Dec 27, 2013, 11:40 AM
I have the EzUHF all setup on my Taranis now and the receiver installed on the Penguin. Made three flights on it yesterday, the third one I set my FPV distance record at 5400 feet.
FPV - 1 mile flight attempt (7 min 2 sec)
Jan 03, 2014, 05:58 PM
FPV Wannabe
FPVAv8tor's Avatar
Thanks for posting this thread smoothvirus. This thread inspired me to pull the trigger on getting into FPV (RC for that matter) and my Penguin arrives tomorrow and I can't wait.
Now that you're flying it a bit, would you do anything differently?
Jan 04, 2014, 02:23 PM
My Penguin Arrived today!! I must say, my initial thoughts were to the size of the fuselage area. It's HUGE! Being 14, I still need the money for the FPV set, but this should be a good first step.
Would anyone know of a decent build thread or build video on this? The manual is very lacking in information. Thanks, nice videos!!
-rt
Jan 04, 2014, 09:06 PM
-rt
You can start with the thread here https://www.rcgroups.com/forums/show....php?t=1684618 It's pretty huge and might be able to answer some of your questions. Or you can click on the various links that the OP posted in his original post here.
Jan 05, 2014, 11:50 PM
The manual is pretty disorganized but thankfully the build itself is pretty easy. I think if you read a couple of build threads you'll be fine.
One trick I learned from building my X8 is when you use the supplied glue (or UHU Por), once it is applied to one of the foam pieces, let it dry for 5 minutes until it is no longer sticky. Makes assembly a little bit easier.
Jan 14, 2014, 01:02 PM
Originally Posted by smoothvirus
I have the RVOSD5 mounted in the fuselage and flew my first FPV flight on the Penguin last Sunday. I still have a couple of things to tweak with the RVOSD but everything went well.
http://www.youtube.com/watch?v=Vl2W_...bayVKuyF_4LMtw
Great job smoothvirus. one question, how did you setup your rx to work with one cable.
im flying a penguin also but i have one cable for each pin, an it looks overloaded on the tail boom
New Product Finwing Penguin FPV Aircraft - information Atflying FPV Talk 605 Jan 12, 2019 09:23 PM
Discussion FinWing Penguin.. as a secondary fpv plane?? Or an AXN? Or bix3... nilshv Electric Plane Talk 8 Jun 02, 2016 05:25 AM
Discussion PENGUIN FPV by FINWING for France FPVizer FPV Talk 14 Jun 29, 2014 03:12 PM
Discussion Finwing Penguin FPV Owners Amfamora Electric Plane Talk 2 Jan 08, 2013 01:55 AM
