RFU - diversity receiver for X10+ - Page 4 - RC Groups
Jan 03, 2014, 01:16 PM
RFU antenna length
Wow, Jim. I'm sure glad I asked. One of the white parts is 13.72 mm and the other is 17.24 mm. Which is correct, 27 mm or 1.1"? According to my calipers 27 mm is 1.063". The short one is almost half of what it should be. I would have thought that would be caught in final inspection. What should I do? Is it ok to trim the shield and clip the wire to 1.963" or 1.1" or 27 mm? ( which one of the above?)
Art
Jan 03, 2014, 07:11 PM
Well, technically 2.45GHz is 27.8mm, which is close to 1.1". If the antenna is shorted or longer by up to .1" it will still work, but be off frequency from dead center.
Jan 03, 2014, 07:43 PM
RFU antenna
Hi Jim,
I was able to trim both antennas to 27.8 mm so that problem should be solved.
Thanks for your help.
Art
Jan 17, 2014, 04:28 PM
Build more, websurf less
FlyingW's Avatar
Jim,
Can I bind the RFU to a transmitter by powering the RFU directly with a 4.8v receiver pack?
If that is ok, then I suppose it is also ok for using the XDP.
I plan to try having it talk SBUS to a Skookum SK540 flybarless gyro.
Please advise. Thanks,
Paul
Jan 17, 2014, 04:43 PM
↓↘→ + (punch)
theKM's Avatar
Originally Posted by FlyingW
Jim,
Paul
yup, yup.
Jan 17, 2014, 07:08 PM
Yep!
Jan 17, 2014, 07:46 PM
FlyingW's Avatar
Done - see 3-axis gyro thread. Thanks KM and Jim for the tips.
Feb 25, 2017, 08:07 AM
I'll Fly Anything...
Hi All, I'm using RFU's in First Person View (FPV) Quads - they have great range and can be configured for PPM; which is perfect!
Question 1: What do you do when you chop up one of the Antennae like a blade of grass with the prop during an 'incident?' Do you send the whole receiver back to XTreme Power Systems, or can you get replacement wires? Sorry, no pics. I'm too embarassed.
Question 2: I'm using completely encased RC Car tubes to protect these antenna wires. So there are two tubes sticking out of these quads at a 90 degree included angle. Could I tape the antenna wires to the bottom of the quad at 90 degrees and still be okay? I am pretty sure not, but looking for guidance in this relatively new field of RC.
I could test this and report, but I do not want to be regarded as an idiot... Just saying...
Ross
Feb 25, 2017, 03:02 PM
I was forwarded your email from Tech Support about this question. I will just answer you here...
The RFU has to come back to get the antenna replaced. It's a free replacement, you just pay for the shipping to/from us.
As long as you are not taping the antenna (the white portion of the coax wire) directly to metal or carbon fiber, it will work fine.
Mar 11, 2017, 03:10 PM
Thanks Jim! I'm working on a package to send your way. I remember seeing some instructions about having repairs staged in such a way as to include additional items placed in the shopping cart so as to combine items for shipping?
Ross
Mar 11, 2017, 04:09 PM
Look at the top of the home page of our website. You will see a link for repairing a product. You will add the "repair" to the shopping cart just like you would any other product. You can place any other items you want in the cart and then check out. When our system sees that there is a repair in an order, the order is held until the item to repaired has arrived, and then the repaired item and rest of the order is shipped back at the same time.
Mar 12, 2017, 06:35 PM
Got it Jim, worked like a charm (or in this case, the way it was programmed). Thank you,
Ross
Jun 03, 2017, 09:55 AM
FlyingW's Avatar
Jim,
I was reading the popular X10+ thread and am now thinking about one of my earlier setups.
I have an RFU and X10+ combination. I want to use the X10+ to control failsafe as per your recommendation.
How do you turn off the failsafe in the RFU so that the X10+ is in charge of failsafe operations?
Paul
Jun 03, 2017, 10:34 AM
You just have to make sure that the failsafe overrride is ON with the X10+. The X10+ knows about the receiver that is connected to it. When the RFU has a failsafe, that information is passed to the X10+. If the failsafe override is ON, then the failsafe is handled by the X10+ itself and the data from the RFU is ignored. There is no way to shut off the failsafe on the RFU (it's a serial data stream, so you can't just shut off the stream), but the X10+ can be told to ignore it, and that's the default setting for the X10+.
Jun 03, 2017, 12:38 PM
FlyingW's Avatar
Ok got it Jim.
Verified two green LED flashes while in Failsafe Override (purple LED) push-button programming mode.
Hope to coax the old Four Star 120 back into the air this season.
Paul
p.s. It would be real nice to be able to set all of the X10+ programming options using the serial link and XDP software instead of the push-button programming mode. But I suppose an advantage of the push button method is that you do not have to disconnect the cable from the Rx.
