Apr 29, 2019, 09:56 AM
glider304guider's Avatar
Hey Lenny,
Wow I was way off. Thanks for the advise. I'll try it out on 3S first and then move up to the 4S configuration.
Missed you at the F5J contest in NC this spring, I meet you out here last year.
Duane
Apr 29, 2019, 10:00 AM
Balsastaub's Avatar
If it is really a 1.5D this is correct, but strange. The plane was designed for High Voltage batteries. The 1.5Y motor would be for 6-8 cells...
May 21, 2019, 05:27 AM
Got to maiden the Formula last week. Wow! I was impressed! Took it up to 500ft and came screaming down proceeded by a large circle around our group of pilots. One of the pilots asked how much throttle I had on it while circling our position. I told him that i had no throttle on and he couldn't believe it. Love the energy retention! I can see why everyone loves these planes.
Jun 16, 2019, 11:58 AM
Finally had the chance to fly the Formula in a 4s configuration. So far all my flights have been in a 3s configuration. Flys great on 3s, but when I go with a 4s battery the motor is cutting out on me. If I go with half throttle it seems to do OK.
Its a Neu 1509/1.5D motor, 6.7 gearbox
Castle ICE Lite 100 speed control
RFM 16X17 prop, 38MM RFM spinner
I guess I new to get a watt meter out and see if its pulling too many amps.
I'm using Tattu - 4S - 2300mah - 45C LiPo Batteries.
Or could it be some kind of setting with the speed controller?
Thanks for any input.
Glider guy trying to figure out this electric stuff.
Jun 16, 2019, 01:52 PM
One Idiot is plenty...
Dbox's Avatar
Settings for ICE and ICE HV controllers when for F5B use:
Use software version 4.01 or higher!
# Castle Link Data File
# Created: Monday, December 03, 2012
# Do Not Edit This File By Hand
Brake Delay: No Delay
Brake Ramp: Immediate (*)
Motor Start Power: 59
Direction: Forward (*)
Brake Strength: 100
Current Limiting: Disabled
BEC Voltage: 5(not for ICE HV)
Power-On Beep: Enabled (*)
Motor Timing: 0
Data Log Enabled: 255
Vehicle Type: Airplane
Throttle Type: Fixed-Endpoints
Throttle Response: 10
Auto-Lipo Volts/Cell: (lowest setting available)
PWM Rate: 24 Khz
Voltage Cutoff Type: Soft Cutoff (*)
Current Cutoff Type: Soft Cutoff (*)
Link Live Enable: Disabled (*)
Jun 16, 2019, 04:47 PM
I'll look into the settings of the speed controller. Thanks
Jun 20, 2019, 07:50 AM
Put an Amp meter on it . 3S pack goes to full power drawing 70amps. When I go with the 4S pack as soon as I throttle past 70amps the motor cuts off. Ordered a castle link so I can check the speed controllers settings. I'll post when I check that. Thanks
For Sale Yuri Composites Formula HV BNF txshan130 Aircraft - Sailplanes (FS/W) 9 Sep 08, 2019 02:10 PM
For Sale Formula HV BNF Will ship txshan130 Aircraft - Sailplanes (FS/W) 0 Nov 06, 2016 10:53 PM
For Sale Formula HV BNF cheap txshan130 Aircraft - Electric - Airplanes (FS/W) 0 Oct 16, 2016 06:30 PM
For Sale Formula HV BNF! txshan130 Aircraft - Sailplanes (FS/W) 0 Sep 29, 2016 02:10 PM
For Sale Yuri Composites Formula HV BNF txshan130 Aircraft - Sailplanes (FS/W) 3 Aug 29, 2016 07:09 PM
