AD1 by ActionDrone. Folding carbon fiber frame with plug and play gimbal system! - RC Groups
Oct 24, 2013, 02:02 AM
ActionDrone's Avatar
New Product
AD1 the folding carbon fiber frame with PNP gimbal system for your GoPro3
This is a very well thought off designed quadcopter by Yoken that integrates a very good plug and play gimbal system. No programs to mess with. Just plug and play! This was designed in mind to create a very light folding frame that folds for portability! This is great for travelers who would like to bring back their memories through their GoPro3 lens.
PLEASE READ SOME OF THESE REVIEWS! They have very helpful tips to building and owning the AD1.
PRIVATE REVIEW LINKS
By: Stephen Cinch from RCGroups https://www.rcgroups.com/forums/show....php?t=2096291
By: Mike Mas https://www.rcgroups.com/forums/show...&highlight=ad1
By: Allenzee https://www.rcgroups.com/forums/show...&highlight=ad1
By: Jason Cole https://www.rcgroups.com/forums/show...&highlight=ad1
By: CactusJackSlade http://uavtechreview.com/Ad1Review.htm
AD1 2014 Flying around San Diego hills. 3rd person view of AD1 flights (2 min 15 sec)
Whale Watching with our Quadcopter AD1 from Action Drone at Puerto Vallarta! (4 min 10 sec)
AD1 2014 Build (1 hr 22 min 17 sec)
Specification:
Airframe + Full Gimbal System(motor x2 + control board + IMU)
- Full Carbon Fiber.= 508g (3K matte surface)
-Airframe made out of 1.5mm board.
-16mm round tubes x4
-16mm round tube clamps & motor mounts,
-2 axis brushless gimbal in the front designed for Gopro 3 only. (comes with 2 brushless motors, control board & IMU installed) plug and play. No software downloads necessary
-Gimbal motor GM2208-80 x2,
-Top transparency protection cover made out of strong polycarbonate
-Front Lens cover made out of 1mm strong polycarbonate
-Motor to motor 590mm (CG still in the x center, same as standard quadcopter),
-Total Flying weight about 1830g (included GoPro, GPS & 4S 5000mah)
Frame Opened: length: 435mm,wide: 530mm,height: 105mm
After Folded (without props): length: 510mm,wide: 185mm,height: 105mm
After Folded (with props): 590mm,wide:185mm,height:105mm
Oct 24, 2013, 09:38 PM
Tested some windy days well just around 10 mph wind and also on a bumpy golf cart ride. Here's a quick clip of it.
AD1 test flight on gusty 10mph wind and on a golf cart to test how well the gimbal works! (0 min 42 sec)
Oct 24, 2013, 11:33 PM
Received my order yesterday and started the build at night.. my first impression on this quad is great, seems like a well thought design.. i like the idea of using o rings on the motor mounts side making the entire body filtered from vibration..
I have yet to see if the plug and play brushless gimbal is indeed plug and play. If it is then, it i can say it worth it buying this frame.
Oct 25, 2013, 12:44 AM
Let me know if you need a manual. I'm working on cleaning it up. If you have any questions just email me and i'll help you out or Yoken can also help you out.
In regards to the gimbal it should just be plug and play as soon as you plug in the power. I have a separate battery plug in for the gimbal with a small 3s battery. It has 250mah battery and it last me pretty much 2 full battery flights at 4500mah each battery.
Oct 25, 2013, 03:45 AM
Si vis pacem parabellum...
parnassus's Avatar
Hi guys, that's the way i like to fly with my big mercedes!!!!
2° volo spyder pro (5 min 5 sec)
Oct 25, 2013, 10:20 AM
wow that just loooks so awesome! I can't believe you have a 30 min flight quadcopter!
Oct 25, 2013, 08:38 PM
Hello all please let me know if you need some help assembling the frame. We just finished the manual and I can email that to you as soon as possible. Also I have had a few people ask me about the 4in1 esc please email personally so i can answer your questions right away.
Oct 26, 2013, 05:28 AM
parnassus's Avatar
I programmed this way, tell me what you think please.
Motor Timing ................... HIGH
Frequency High ....................... HIGH
Acceleration starts up ..... ACCELERATE
Oct 27, 2013, 03:41 PM
Are you using Naza M? They recommend that you program High. I always just leave everything stock.
Oct 29, 2013, 12:39 AM
great frame...
[DJT] latihan di lap. KSU-Depok, 6 okt 2013 (2 min 52 sec)
gmap:
https://maps.google.co.id/maps?q=cib...+Java&t=h&z=18
Oct 29, 2013, 01:35 AM
[DJT] Stadion Baru di Cibinong (3 min 50 sec)
gmap:
https://maps.google.co.id/maps?q=cib...+Java&t=h&z=17
Oct 29, 2013, 01:51 AM
Nice flights!! What are they building?
Oct 29, 2013, 01:59 AM
4in1 ESC SimonK Flashed for AD1
Hey guys just wanted to give some first pictures for the
AD1 SimonK Flashed 4in1 25A ESC!!
* Simon K Flashed
* You can replace a damage ESC easily. Nothing is soldered.
* Just plug the wire leads to the side and screw it in from the bottom. Makes it easy to adjust your wire length if needed.
Oct 29, 2013, 02:01 AM
gmap:
they built a stadium..
Oct 29, 2013, 02:05 AM
Originally Posted by risdyant
Love your videos do you mind if I put that on ActionDrones Facebook?
https://www.facebook.com/ActionDrone
