This thread is privately moderated by burkefj, who may elect to delete unwanted replies.
Oct 20, 2013, 11:10 PM
burkefj's Avatar
B-58 Hustler
Since I lost my original B-58 in a tree several years ago, I've been missing it.
So, I broke out the plans, made some modifications, and decided to save a bit of weight, would just keep it in the white, which also allowed me to do panel line detail.
It is 12 oz, without esc, motor and battery. 32" ws and 49" long. I doubled all the way to the fuse nose this time, and used 6mm doubled on the motor pods in this version.
I didn't want to splice that much so I used four compete 27.5x39" depron sheets and there was a lot left over, I only spliced the center section nose about 10" or so. Not much carbon needed, just some strip in each engine pod, two wing spars and a tail strip for stiffening. I did use some leftover spar rod in the tail to secure the motor plate to right where the stinger on the model would be. I've switched to a microjet V-3 grayson motor with apc 6x4E prop. I've flown it with a single 2100 lipo placed right around and under the leading edge of the right wing and 25+ amp esc and also with two 800mah 3s packs in parallel, with a battery placed on each side of the nose. The two battery version is lighter but has shorter run time, the 2100 pack has more current available and more thrust.
RTF is around 20 oz with two 800mah cells and 18 amp esc, 24 ounces with 2100 3s pack and 25 amp esc.
Here's the new video...
Note, on handlaunch since you are holding the fuel pod and the motor is up higher on the model, it tends to pitch down on launch before you get flight speed, so plan on this,launch with a slightly nose up attitude, and get on the elevator quickly to get the nose up for climb out.
Scratch Built RC B-58 Hustler pusher parkjet (1 min 54 sec)
Frank
For Sale Keith sparks B-58 hustler 80% complete maverick pro Aircraft - Electric - Jets (FS/W) 18 Jul 08, 2016 07:57 PM
Question B-58 Hustler for PSS? sloperut Slope 43 May 15, 2004 09:26 AM
B-58 Hustler project gutboy17 Electric Ducted Fan Jet Talk 34 Feb 19, 2004 06:03 PM
Micro B-58 Hustler flailing Scratchbuilt Indoor and Micro Models 7 Apr 17, 2002 02:43 PM
Micro B-58 Hustler flailing Electric Ducted Fan Jet Talk 0 Apr 17, 2002 11:57 AM
