Turnigy 9XR Pro, new open source radio - Page 361 - RC Groups
Nov 10, 2017, 08:59 AM
Flying a Chipmunk in Portugal
jhsa's Avatar
Originally Posted by rfcgt
Can I take the eeprom file and restore it to anorther 9xrPro, with r221?
If they have the same hardware configuration, like the same number of pots, switches, etc, then yes.
But you will have to calibrate sticks and pots on the radio you've just copied it to.
The calibration settings saved on the eeprom are from the radio that supplied the eeprom..
Joćo
Nov 10, 2017, 09:30 AM
treefinder
springer's Avatar
I happen to have the TGY tx lipo with "protective circuit". I haven't tried charging it with the 12 v connector. Like Joćo, i figured it had no balancing circuitry, i typically recharge it once a month by connecting up my little 850mah charger to the balance connector and trickle juice into it while i am working on planes. I fly several times a week, and easily get a month out of it.
Considering how long the pack lasts i could charge through the port and every other month do the balance charge, i suppose. But i have the balance charge habit now
Interestingly the only one i know who had a catastrophic fire was charging nimh batts, left to go to store, and came back to find his house in flames. I have wondered if something else was going on there as i've never heard of another nimh battery fire.
Nov 10, 2017, 10:12 AM
jhsa's Avatar
Me neither. As far as I know they just "Vent" (is this the right expression?) if REALLY overcharged..
But still they are much less likely to catch fire than lithium batteries.
Well, me being curious about it I have just searched about the subject. What I found is that they can catch fire but you will really have to mess with them, like shorting a full battery or opening it. As you can see on one of the videos one of the batteries caught fire, but because it was fully charged and then they have shorted it. Perhaps it was what happened on the case you mentioned above
Joćo
5100 MAh NiMh Akku in Flammen. 5100 MAh NiMh battery in flames (4 min 24 sec)
Overcharging an old NiMh battery pack (2 min 30 sec)
Nov 10, 2017, 04:27 PM
treefinder
springer's Avatar
I suppose, as I recall there wasn't much left to analyze. Could have been the charger itself, depending on which type he had. Might have been one of those fancy ones that charges all types. I have steered away from chargers with too many capabilities, as I have other friends who inadvertently set the wrong settings and nearly toasted packs. My lipo chargers are all simple ones with switches for amp draw ( and max of 2 or 4 amps), and LEDs for charge state - hard to mess up.
I suppose the takeaway is that all batteries have some risk, and the more powerful have more risk. Like a chain saw, table saw, etc, they are useful tools but must be respected for what they can do and what damage they can cause and treated accordingly.
Nov 10, 2017, 05:37 PM
jhsa's Avatar
Yes, all must be respected, but LiPos are special on their own
Yes some chargers are dangerous and it is very easy to cause a disaster if we are not paying attention to what we are doing. I have a couple of those Imax B6. For example you connect a 2s Lipo battery and select 3s on the charger and then press start. The charger will warn you that the cell count is incorrect. But if you insist and press start again, it will actually start charging the battery with the incorrect settings. I have tested this on these chargers, and it really happens. It could also explain why my club mate nearly burnt his house down.
I have another charger that I have bought from HK recently that it doesn't start charging if the setting is incorrect, and it actually beeps like hell. We must be really careful with these things.. LiPos are dangerous whether they are 1C or 30C. NiMhs can also be dangerous, but they will take way more abuse before they catch fire..
Joćo
Nov 27, 2017, 05:54 AM
ukbren's Avatar
anyone here using the 9xr pro with tbs crossfire (micro)?
i currently use an XJT on my pro, and the old/old orange dsm2/x module on my non-pro, but am thinking of going for the TBS instead of the frsky. i'm assuming the outgoing signal would be fine, just concerned about rssi/telemetry...
Nov 27, 2017, 09:01 AM
Still tryin'
There is someone on the Open RC Forum who has been using the full size it sounds like. He's also using Ersky9xr firmware. See thread at link, only 3 pages so not too much reading. I'm going to switch to the cross fire micro as well just not sure when.
http://openrcforums.com/forum/viewtopic.php?t=8665
Nov 30, 2017, 07:04 AM
Voc
£22 now from hobbyking stock in UK and EU warehouse
Nov 30, 2017, 05:23 PM
Zaphod69's Avatar
Just picked one up as a Christmas present for a friend
Dec 01, 2017, 04:31 AM
thanks for the heads up. snagged a spare .. can't refuse at that price
Dec 01, 2017, 09:14 AM
Get them while they last , They are not longer making the 9XR Pro anymore.
Dec 01, 2017, 10:58 AM
WHAAAAAT discontinued<OO> damn glad i snagged one. so what are they replacing it with?
Dec 03, 2017, 02:09 PM
Originally Posted by Mike Blandford
There is a fuse in the battery circuit (FU1).
I think that R9 sometimes fails due to mechanical bending of the PCB. It is a larger component than some others.
For reference, it is: 0.1R 1% 1/4W (that's a tenth of an ohm).
It's purpose is to provide a current measurement so you know how much current the Tx is using.
Mike.
Hi all,
Been following this thread for some time now, but was trying to get a flight sim working, plugged in the Futaba connector connected to PC and all went blank. When I opened it, the R9 had blown.
Is it safe to operate with this shorted?
FWIW, the - cable from the battery was also becoming loose and was at the point of breaking off the board (did after i removed the board). Might be worth checking if anyone is opening theirs.
Rgds
Dec 03, 2017, 04:21 PM
Ersky9x Developer
Mike Blandford's Avatar
Yes it is safe to short out R9, you won't see a radio current reading anymore.
However, please check what the Futaba connector you used does. One of the Futaba connections is the power for the RF module. If R9 blew when you plugged the Fuaba connector in, then I would guess the RF power signal in the connector got shorted to ground. Pin 1 of the Futaba connector is ground, pin 5 is the RF power.
Mike.
Dec 03, 2017, 04:23 PM
Hi Mike,
Thanks for that (again I believe).
I would say that's what happened alright.
Many Thanks, Luke
