Data
OwnTX / OpenTX - Displays, MCU boards etc. that work with OpenTX and similar firmware
As I already suggetsed in this post: https://www.rcgroups.com/forums/show...&postcount=754 I would like to start a List of hardware that is known to work with openTX and similar firmwares.
As a start this is the list of components I used to do my Futaba FX-18 to Open FX-18 conversion: MCU Board http://www.ebay.de/itm/ATmega128-M12...X:DERP:DE:1123 Display: http://www.ebay.com/itm/12864-128X64...E:L:OC:DE:3160 Two Axis Joystick Switch: http://www.pollin.de/shop/dt/OTEzOTc...A413G_LFG.html |
I did a very simple conversion using a HK T6 transmitter and a Turnigy 9XR main pcb.
The 9XR connector pinouts are in a pdf file here. There is no display, it is running er9x firmware, and holds one model that is loaded or modified with eepe. pics here: https://www.rcgroups.com/forums/show...&postcount=765 https://www.rcgroups.com/forums/show...&postcount=771 |
MCU adapter board:
http://www.ebay.nl/itm/2Pcs-0-5-0-8m...82dbbcf&_uhb=1 (if the link doesn't work, just search for 'TQFP 64 pcb' on ebay). I prefer the rectangular ones, because they are a bit smaller than the square ones. Plus they have plenty extra holes for crystal, capacitors, and some spare VCC and GND connectors. LCD ZIF adapter board: http://www.ebay.nl/itm/Multiple-0-5-...a0d6a59&_uhb=1 (or search for '0.5 mm pitch adapter board' on ebay) regards, Feddo |
Hope you do not mind some input from me.
For core 9x diy I ordered blank development pcb as I had spare m128 as some others may also:- http://www.ebay.co.uk/itm/1709978825...84.m1438.l2649 LCD display:- http://www.ebay.co.uk/itm/1906889861...117%26_rdc%3D1 I am working on 9xr pcb diy from Hobbyking as linked by Ian444 in above post. LCD display ERC12864FSF-4 :- http://www.ebay.co.uk/itm/12864-128x...item43bd41a738 regards, Ashley |
OpenAVRc for mega2560 core |
Thread Tools | |
Similar Threads | |||||
Sold | KK2.0 Multi-rotor LCD Flight Control Board with Firmware v1.5 and Servo Leads | yarg | Aircraft - Electric - Multirotor (FS/W) | 3 | Jan 13, 2013 02:32 PM |
Found | anyone has spare HK Board V2.1 laying around? Or something similar for that price? | templton89 | Aircraft - Electric - Multirotor (FS/W) | 8 | Aug 01, 2012 02:32 PM |
Discussion | Devices That Work with KK Controller Board? | rtbchris | Multirotor Drone Talk | 10 | Aug 21, 2011 04:41 PM |
Question | Working with "Sturdyboard" display foam board...help! | Picoflyer | Foamies (Kits) | 24 | Oct 16, 2004 04:00 PM |
