Oct 06, 2013, 08:01 PM
ancora imparo
jj604's Avatar
Correct name for Losi/Walkera 2 pin battery connector
Anyone know the proper name for this 2 pin connector used on small packs?
sammylam and others claim it is a JST-DS
http://www.ebay.com/itm/2-Pair-JST-D...item27d8064740
But I can't find it in the JST wire to wire catalog
http://www.jst-mfg.com/product/searc...1&id=11&page=1
Wasn't able to find it in Molex or Amp either.
Anyone know for sure what it is?
John
(I'll post this in the Indoor thread also)
Oct 07, 2013, 12:05 AM
ancora imparo
jj604's Avatar
I think I found it.
It's a Molex 51006-0200
http://www.molex.com/molex/products/...P_HOUSINGS.xml
Anyone know for sure if that is the case?
Nov 21, 2014, 01:24 AM
uber noober
kumara.kid's Avatar
I think you're right jj604. But the Molex 51005/51006 series can have different numbers of pins.
Part numbers for the plastic housing:
The Losi Micro-T connector has 2 pins, so the part you want is a molex 51005-0200 (male) and 51006-0200 (female); also known as 51005-2P / 51006-2P.
Contact Elements:
The electrical contacts (crimp terminals) are parts # 50012 and 50013.
Links with photos:
Cable socket housing 51005
Cable pin housing 51006
Nov 21, 2014, 01:32 AM
ancora imparo
jj604's Avatar
Thanks.
I had come to the same conclusion.
JJ
Nov 21, 2014, 05:45 AM
ggcrandall1's Avatar
JJ,
Glad you found it.
May I suggest that you photograph white connectors against a dark background. The show up a lot better that way.
Glen
Nov 21, 2014, 05:55 AM
ancora imparo
jj604's Avatar
Glen, totally agree. I normally use Green.
The contrast is a nice balance between showing up the connector and being too harsh.
The pic I included was pinched from a website. Hence the white background.
John
Originally Posted by ggcrandall1
JJ,
Glad you found it.
Glen
Feb 21, 2015, 08:47 PM
Better late than never?
I've also been trying to find the name for this little bugger used on battery packs for the Syma X5C. At this time I believe it is a Molex 51005-2P. I'm still trying to order one to see if it is in fact what the one I need.
FWIW mine looks just like the one in your photo.
Feb 22, 2015, 12:48 AM
ancora imparo
jj604's Avatar
That is correct. The 51005 is the "Receptacle housing" which is the bit with two wings that is on the battery and the 51006 is the one it plugs into.
The 51005 has metal sockets inside the palstic housing and is correctly termed the Female connector and the 51006 has pins so is the Male.
Unfortunately hobby vendors often call the battery connector the Male plug because the outer housing appears to fit inside the connector on the plane or copter and the connector on the plane/copter the Female just to confuse things!
The -2P indicates it is a 2 pin version.
Be aware also that this 2 pin connector comes in BOTH polarities (ie red and back are swapped) depending on the vendor. Losi and Walkera are opposite I believe, but I'm not a quadcopter flier..
Good way to smoke your new little shiny toy.
Moral. Check the wiring colour matches before you plug in the battery.
Feb 24, 2016, 03:16 AM
Here it is nice and concise (and available)...
The 51005-0200 is a 2-way 1-row MicroBlade™ Wire-to-wire Receptacle Housing made of polyester. It mates with 51006 male housing. The crimp housing is suitable for signal and wire-to-wire applications. This 51005 series receptacle housing can be used with 50013 crimp terminal.
Source:
Female Connectors 51005-0200
Contacts (crimp terminals) 50013-8100
Feb 24, 2016, 05:28 AM
ancora imparo
jj604's Avatar
Yep - and note especially that these are "Microblade" connectors not "Picoblade" connectors.
The latter are the small "tall"ones used at 1.25mm pitch as 2pin in Parkzone Ultra micro batteries and 3 pin in Futaba and Chinese micro servos and receivers, these are the larger "flat" ones used in the 2 pin Losi/Walkera /etc battery connections.
Mar 18, 2017, 05:59 PM
luckshot's Avatar
Molex 510050200
Hey all,
Probably way late to this party, but this thread was crazy helpful to me, so I felt like I should contribute in some small manner. Mouser right now has the best price on these connectors:
http://www.mouser.com/Search/Product...538-51005-0200
Running around $0.18 for the male and $0.22 for the female at qt. 10 ea.
Thank you SO MUCH for posting this. Super helpful!
Mar 19, 2017, 01:09 AM
Jaketheone46
I am not sure if this was mentioned in this thread or not but pay special attention to the polarity with any pack that has this plug as Losi and walkera are wired opposite polarity same darn plug. . I have no idea why this is but noticed this with my first quad purchase when I bought batteries for it.
After reading the thread I see Jj has already mentioned this. But this is something worth mentioning a second time so more see it.
Sep 24, 2017, 10:43 PM
What about the same plug for 3 pin?
Sep 24, 2017, 11:18 PM
ancora imparo
jj604's Avatar
This series comes with 2 -10 pins but the versions with more than 6 are marked as "obsolete".
The 3 pin version is the 0510050300 and 0510060300.
Help! Correct identification for Losi/Walkera connector jj604 Scratchbuilt Indoor and Micro Models 1 Oct 07, 2013 12:06 AM
Discussion Name Of Female Connector Pins To Build a Custom Harness For Flight Controller akfreak Multirotor Drone Electronics 4 Sep 23, 2013 03:21 AM
Deans 2 & 3 pin connectors and Multiplex Connectors SOLD Mikey 68 Non R/C Items (FS/W) 1 Jan 02, 2013 02:21 PM
