This thread is privately moderated by CarreraGTSCS, who may elect to delete unwanted replies.
Oct 03, 2013, 07:52 PM
Lori, hey, you're home early
CarreraGTSCS's Avatar
Motor Specs to store
Posting this to remind me of the specs and possible combinations.
Motor: TURNIGY 50-65A 400kv Outrunner
Specifications:
Model : TR50-65A-400
Input Voltage : 14.8V~29.6V (4~8S Li-po)
Kv : 400 rpm/V } within 10%
Current capacity : 60A/60s
Dimensions : 50mm X 65mm / 1.97in X 2.68in
Shaft diameter : 8mm / 0.31in
Weight with cables : 414g / 14.60oz
Number of poles/magnets : 14
Recommended model weight : 3000~4500g / 100~200oz
Power equivalent : .50 to .72 glow engine
My first choice for a a ESC was a TURNIGY K-Force 70A-HV OPTO Brushl,
but it has literally toasted on the first run, ok second choice of ESC:
TURNIGY Plush 80A w/ UBEC Speed Controller
Specification:
Cont Current: 80A
Burst Current: 90A
UBEC Mode: 3A/5v out
Voltage Range: 5.6v ~ 26v
Weight: 91g
Use HIGH timing, 6s 4400 lipo, 15x8 or 16x8
15x8 APCe, 6s 4000 Flightmax lipos, HK SS60-70 esc, 46-47amps, 1050watts
Proctor 1/6th Camel, Plush 80, 4s 4400 lipo, 16x12 Zinger (standard timing)
Alien/EMP/Turnigy C80-100 130kv
Model: HXT80-100-B
Wire Turns: 8
Resistance: 32ohm
Idle Current: 2A
ESC Required: 130A
Input Voltage : max. 48V
Kv : 130 rpm/V
Weight: 1570g
Shaft: 12mm
Voltage Range: 20-48v
Non Load Current: 2.0A
Maximum Power: 6500W
Equivalent: 60-80cc Gas Engine
IT'S A MONSTER ....! ... The largest electric motor we have ever had! Model: EMP 80-100/06; Weight: 1750g; Power Equivalent: 80-100cc Gas Engine; Power: up to 7.0kW (9.4 Horsepower); ..... WITH: 120 HV ESC (see ALLFLIGHT ESC section), and Xoar 27 x 10 propeller, 12S 6000mAh battteries (20C), pulls 104.5A, power=4.6kW, and: PRODUCES 18.2 kg Thrust (i.e 40 lbs of Thrust .....!!) AMAZING ..... JUST INCREDIBLE ...... With: 12S 4100 mAh Li-Po, prop APC 27 X 15, pulls 97A, power 4.3kW, produces Thrust of 13.5 Kg (30lb .... !). .... THIS MOTOR HAS VERY VERY GOOD REPORTS FROM TOP PILOTS: .... Kv: 180 rpm / V; Max current: 150A; Voltage: up to 18 Li-Po (48 V); Voltage Range: 20 to 66V (18S Li-Po); Dimensions: Diam 80mm; Length 122mm; Shaft diam: 12 mm; Recommended prop: 22x12, 24x12, up to 30x15; ESC: 120V or 150A HV type (i.e. up to 12S Li-Po) (Also see: ALLFLIGHT ESC section). ..... ** Comes with full accessory pack -includes prop adapter, spinner, mount plate and screws. .... And remember: Only 1/6 the cost of an equivalent Hacker motor. .... AND every bit as good or even better than a Hacker motor.
__________________
Nov 06, 2013, 10:39 AM
mikecopey's Avatar
Is timing supposed to be changed for different ( 4s to 6s) batteries ?
Thanks !
Jan 18, 2014, 11:12 PM
Thanks !
PM'd you.
Discussion Need Help! T-motor MN4014-9 400kv / Turnigy Plush 40amp ESC / Turnigy 6S LiPo Ahing Multirotor Drone Talk 2 Aug 06, 2013 11:15 PM
Discussion Need Help! T-motor MN4014-9 400kv / Turnigy Plush 40amp ESC / Turnigy 6S LiPo Ahing Multirotor Drone Talk 0 Aug 02, 2013 12:30 PM
Sold Turnigy Aerodrive C5065-400 8s $40 shipped java8297 Aircraft - Electric - Power Systems (FS/W) 1 Aug 03, 2009 07:04 PM
For Sale Turnigy C5065-400 Motor Mikey 68 Aircraft - Electric - Power Systems (FS/W) 0 Mar 27, 2009 11:58 AM
Sold Turnigy Aerodrive C5065-320Kv motor $55 Shipped xwingnut Aircraft - Electric - Power Systems (FS/W) 7 Jun 17, 2008 11:08 PM
