Oct 01, 2013, 11:20 AM
that's gonna hurt...
Winch and Retriever info collection
Starting a thread to store winch and retriever data - feel free to comment and I will add info to the top threads ...... Bruce
Consumables
Winch line
http://www.memphisnet.net/product/22...tebraidedseine 240lb test
http://www.memphisnet.net/product/22...-braided-seine 290lb test
Retriever line
Brake belts ( I like the 0.5" belt, it seems to fit the pulley better and gets stuck less. Always verify length against belt being replaced due to variations in winch construction )
0.38" wide belt - cut to 11.75" long
http://www.oreillyauto.com/site/c/de...6&keyword=1400
0.5" wide - cut to 12" long
http://www.oreillyauto.com/site/c/de...1570&ppt=C0218
Solenoids
http://www.oreillyauto.com/site/c/de...6&keyword=s63p
Batteries
Costco Kirkland Marine - Item # 12852 - Marine Cranking Amps 750 - Cold Cranking Amps 600
Motor Brushes
http://www.napaonline.com/Catalog/Ca...502_0192417793
Oct 01, 2013, 11:24 AM
Dual Solenoid Project
Stuck Solenoid Alarm Schematic and parts list added.
Thanks to Randy Shore for the alarm design and build.
Copper buss bar stock - 0.125" x 0.625" x 24"
http://www.amazon.com/dp/B000H9JRL2/ref=biss_dp_t_asn
Bruce
Oct 01, 2013, 11:26 AM
Other information
Winch and retriever maintenance / rebuilds
Foot pedal
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Master power switch
Quick release battery clamps
Old style http://www.amazon.com/Battery-Caps-Q...sim_sbs_auto_8
New Style http://www.amazon.com/Minn-Kota-1820...ery+Connectors
Oct 02, 2013, 03:15 PM
Brake belt replacement
Info to be added
Oct 03, 2013, 06:44 PM
Where do you take the motors to be rebuilt?
Oct 03, 2013, 11:43 PM
San Jose Generator
40 San Jose Avenue
San Jose CA 95125
408-293-2200
Rod Stuart (owner)
I was there today
Bruce
Nov 22, 2013, 10:54 PM
I just got some new quick connect battery clamps - they were cheaper and I like them a LOT more. Better design, stronger clamp for the battery cables, plastic cover has tabs to prevent it from coming off. We shall see - I bought 2 sets.
Bruce
Feb 01, 2014, 02:56 PM
Just edited post #1 for brake belt info, I added a 1/2" belt option. Also note that these belts are not commonly in stock, but can be ordered and in-store in 1 day. If you are hurting, do a search on O'Reily Auto parts for Lawn and Garden Belts and check for availability in-store.
http://www.oreillyauto.com/site/c/se...1570/C0218.oap
Bruce
Feb 06, 2014, 11:42 AM
Hey Bruce,
I still have more of the #2 cable and some crimp lugs that the club paid for. Let me know if need more pieces made up.
Tim
Dec 09, 2014, 12:50 PM
Retriever replacement switch for arm down operation
NKK S45
http://www.digikey.com/product-detai...925-ND/1007003
Also available here ( thanks Randy )
http://www.zoro.com/i/G1205784/?utm_...ontent=general
Bruce
Apr 04, 2016, 06:48 PM
Hands Free Retriever Switch P/N
This is for the large 12 position 4PDT switch.
Digikey part 360-1925-ND.
Dec 23, 2016, 07:54 PM
SBSS, SVSS, SCCMAS, EBRC
Don McCullough's Avatar
Retriever One-Way Bearing
On Thursday the one-way bearing on the retriever stopped working. Remembering what to do with a heli one-way, I cleaned it with penetrating oil spray (nasty blackness emerged) then lubed it with Tri-Flow. It right away worked and after a few revolutions was somewhat smooth.
Lesson, periodically lube the one-way. They do not work when dry. Just penetrating oil won't do it.
We will see how it performs. Hopefully we won't need a new bearing. Allen wrenches for the retriever and Tri-Flow were added to the retriever bag.
Don
Jun 09, 2017, 12:09 PM
Foot Switch
Linemaster Treadlite II t-91-SC36
https://www.linemaster.com/products/...adlite-ii.aspx
Aug 11, 2017, 12:00 PM
Retreiver cam arm switches
V-15G5-1C26-K P/N
https://www.digikey.com/product-deta...SW136-ND/31098
Aug 11, 2017, 04:38 PM
This is a great place for this info.
For Sale winch and retriever naylor900 Aircraft - Sailplanes (FS/W) 2 Jul 03, 2013 01:29 PM
Discussion Winch and retriever you may already own (mostly) 2motheus Sailplane Talk 5 Jul 02, 2013 01:09 PM
Sold Rahm winch and retriever on trailer charlesbair Aircraft - Sailplanes (FS/W) 3 Apr 10, 2013 11:12 PM
For Sale Rahm winch and retriever Bile Aircraft - Sailplanes (FS/W) 3 Feb 10, 2013 11:00 AM
Wanted Winch and Retriever Skytrek Aircraft - Sailplanes (FS/W) 4 Jan 23, 2013 07:55 PM
