Oct 21, 2013, 04:57 PM
Comin' in HOT!
tdford's Avatar
I haven't seen any 9g servos that couldn't work at 6v. I would think your safe, but yeah good luck finding any specs on them. I've heard of older servoless retracts that work better at 6v and those plane's servos had no problems.
Nov 06, 2013, 05:56 AM
A man with too many toys
Is anyone getting one of these – I am thinking of ordering one?
Nov 06, 2013, 07:15 AM
You win again gravity!
SMorrisRC's Avatar
Have got one, but not flown yet due to the weather
Nov 06, 2013, 08:36 AM
Was everything a good fit?
Is there plenty of room for a 4s battery?
Nov 06, 2013, 10:48 AM
Comin' in HOT!
tdford's Avatar
Motion's site says 4s 1600-2200mah 30C packs. And from looking at the pic it looks like it wouldn't fit much more withough carving some foam.
The ESC and Rx are housed underside I believe (little help SMorris) so at least you dont have to worry about that stuff taking up room.
Nov 06, 2013, 02:06 PM
SMorrisRC's Avatar
The esc is mounted in a recess on the underside - very nicely done. The Rx has to fit in the battery compartment.......easiest place is right in the nose. You can fit a 2200mah 4s, but it's snug.
Nov 06, 2013, 03:19 PM
Comin' in HOT!
tdford's Avatar
Yeah if the servo leads are long enough you could put the Rx way up in the front.
Nov 09, 2013, 10:47 PM
Cheese5's Avatar
Its in stock at motionrc. Is this a good jet to buy? My 50mm jpower F-22 was totaled today, looking to get a more scale F-22. This one looks good, does anyone have one yet? (haven't seen a video of it flying yet).
Nov 09, 2013, 10:55 PM
CWE STL
Tspine's Avatar
Mine shipped Friday, I'm sure you'll see a lot of feedback soon.
Nov 10, 2013, 05:51 AM
Did you get the 3s or 4s power system?
Nov 10, 2013, 10:13 AM
CWE STL
Tspine's Avatar
4S for sure
Nov 10, 2013, 06:38 PM
Comin' in HOT!
tdford's Avatar
4S for sure
Nice, look forward to your review.
Nov 11, 2013, 09:32 PM
CWE STL
Tspine's Avatar
It arrived today! I had almost no time to mess around with it today. So I open up the box just to look everything over...and about 15 min later it was ready to rock. My plan from the begining was to remove the gear. The nose gear is a part of the plastic tray for the stearing servo so I'll need to fill the gap with foam before it is ready for a maiden. Note there are two different control rod diameters and the same for the horn links. I never opened the manual, it may specify that in there. Also the plastic rod attachment for the elevator needed minor sanding to slide on. It may snow here tonight so tomorrows maiden probably won't happen. I'll work on filling the nose before work. It may need AK vertical stab markings!
Nov 11, 2013, 09:37 PM
I feel vigorous!!!
Vigorous's Avatar
I am also thinking to remove the gear and hand launch. Can I ask what kind of foam you are going to use to fill in the nosegear hole? I've never had to do that before...thanks
Nov 11, 2013, 11:46 PM
CWE STL
Tspine's Avatar
I'm not sure that it matters what type of foam you use. That area shouldn't be under any real stress. I may may cut a few pieces of depron board I have laying around. I won't fill the whole void, only the underside of the nose.
For Sale 64mm f-22 raptor arf thundercracker Aircraft - Electric - Jets (FS/W) 18 Apr 17, 2018 12:37 AM
Wanted 64mm F-22 joe1 Aircraft - Electric - Airplanes (FS/W) 1 Jun 25, 2015 09:05 AM
For Sale F-22 $ 60.00 64mm Shumate design converted to edf VIDEOPRO Aircraft - Electric - Jets (FS/W) 1 Aug 11, 2014 10:48 PM
Discussion Advice for F-22 Camo Raptor 64mm 4CH RTF Ducted Fan RC Jet anthjames Foamies (Kits) 1 Jul 03, 2013 09:44 PM
Sold Starmax F-22 EPO 64mm EDF ARF, New version Joe 1320 Aircraft - Electric - Jets (FS/W) 1 Jul 16, 2012 11:21 AM
