This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Sep 27, 2013, 11:48 PM
Jack Crossfire's Avatar
Gearbox success
After many weeks of hacking gearboxes, the gearbox which finally had enough torque & hackability was the pololu 25D 75:1 gear motor.
Despite being enclosed, it actually unbolted. The pinion gear was removable without a pinion puller.
It's not a planetary gearbox. 1/2 the space is unused. The gears fall out all over the place when opened.
Then the pinion is press fitted on some 1/16" heat shrink on the stepper motor. This was very loose fitting, but the motor torque is so vanishingly small, it was believed to be tight enough.
Transparent heat shrink was much tighter fitting, but required loosening the gearbox slightly to keep from jamming.
The new motor fit snugly.
The new motor is glued on.
A rover platform can finally get around carpet using the stepper motors. The wheels aren't exactly parallel. It isn't perfectly level.
Using that particular gearbox with the matched brackets, wheels, & wheel adapters came to $67 + shipping. That's the price of making a very accurate drive train with stepper motors without machine tools.
Discussion Another Success Story for the Obama Administration. LcJ Life, The Universe, and Politics 77 Jan 20, 2013 01:05 AM
Has anyone successfully glued GWS gearboxes back together? Martin Hunter Parkflyers 9 Jul 22, 2002 10:25 AM
