This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Sep 24, 2013, 09:06 PM
Jack Crossfire's Avatar
Pololu gearbox fail
The attraction to this gearbox was that it was open, allowing you to disassemble it more easily.
It turned out extremely tiny.
The motor was bolted on, but the gearbox doesn't come apart.
The pinion gear couldn't be removed without destroying it. It has a 1mm shaft & 2.4mm outer diameter. These details aren't given on the internets.
It would require grinding down the stepper motor shaft to exactly the right diameter, not likely to happen with hand tools.
There is exactly 1 pinion gear remover which can remove a 1mm shaft, the mighty e-flite pinion puller, but it breaks easily. It would require fabricating replacement pins out of a steel rod.
Discussion FY-DoS Connection failed! Firmware upgrade open failed! teohcheesoon UAV - Unmanned Aerial Vehicles 1 Mar 20, 2014 06:11 PM
Careful! Fail safe systems do fail! rodneyf Electric Plane Talk 8 Feb 24, 2013 11:53 PM
Help! When a servo fails mid flight, what position is it likely to fail in? CB Flyer Radios 9 Sep 19, 2010 10:25 AM
Discussion Socialist medicine failing to fail? Norman Adlam Life, The Universe, and Politics 37 Aug 13, 2010 07:50 AM
