This thread is privately moderated by Thomas B., who may elect to delete unwanted replies.
Sep 23, 2013, 01:00 PM
scratchbuilder
Thomas B.'s Avatar
Edge 540
I built this Edge from 3 and 5mm Depron. Span is 70 cm, weighs 320g, 3s lipo, GWS 2208/18T with GWS 9x4,7 prop. Wing has hollow symmetrical airfoil.
Edge 540 (2 min 54 sec)
Oct 06, 2013, 03:21 PM
For flying out loud!
planemad man's Avatar
that looks brilliant!!!
plans?
dimensions?
i think i may build this instead of the yak
Oct 06, 2013, 03:22 PM
also what mah li-po
Oct 08, 2013, 09:09 AM
scratchbuilder
Thomas B.'s Avatar
This is a sweet flying plane!
Lipo is 800 to 1000 mah 3s
Here are my sketchup sketches. The airfoil is not correct in the sketch.
It has a 15 x 6mm balsa ( depron should work, too) spar 60mm from leading edge and the depron is bent over it.
The fuselage is a very simple box with a ply firewall and only one more depron spacer at trailing edge. The upper part of the fuselage is just profile shape.
Oct 08, 2013, 09:57 AM
scratchbuilder
Thomas B.'s Avatar
The fuselage is a box/profile hybrid.
Forgot in the sketch: Wing chord at wingtip is 140mm + 50mm aileron, Spar height is sanded to 14mm at tip.
Oct 13, 2013, 01:09 PM
How many sheets of foam did it take to build this? How much 3? How much 5?
Oct 14, 2013, 02:41 PM
scratchbuilder
Thomas B.'s Avatar
Not sure about this - about half a sheet 3mm for wings and fuselage and some scrap parts 5mm for the tail and ailerons.
Oct 15, 2013, 12:19 AM
cool sounds like it wont use to much
Discussion 50cc AW Edge 540 V.S EF Edge 540 Feliperc Fuel Plane Talk 5 Nov 23, 2013 11:18 PM
Question 3DHS Edge 48" vs Extreme Flight Edge 540 Exp 48" Dan the man 3D Flying 9 Jul 29, 2013 01:42 AM
Discussion Fliton Mini Edge 540 or E-flite Mini Edge 540? That is the question. CGReload 3D Flying 4 Feb 13, 2008 03:17 PM
Poll Mini Katan V Fliton Edge 540 V Fliton Edge 540 Cliddy 3D Flying 30 Feb 08, 2006 04:47 AM
Poll Mini Katan V Flinton Edge 540 V Filinton Edge 540 Cliddy 3D Flying 2 Feb 05, 2006 06:23 PM
