Sep 18, 2013, 01:52 PM
Do it Right, the first time!
CoolerByTheLake's Avatar
Yep 120a Hv
For those who have waited.
Just a heads up!
YEP 120A HV (4~14S) Brushless Speed Controller (OPTO) to your watch list in www.hobbyking.com and this is an email to let you know that we have received a shipment just now!
Click below to view this item;
Hobbyking YEP 120A HV (4~14S) Brushless Speed Controller (OPTO)
Sep 18, 2013, 08:36 PM
Closed Account
Are the programing cards in yet?..............Just checked.......They are.
Sep 18, 2013, 08:49 PM
Foam addict
4stripes's Avatar
Be sure to get the programming card as it is necessary to set up. Even with the card it is tricky. The short wire from the ESC goes to the lower middle connection on the card, but the ESC main battery has to be hooked up, along with a flight pack battery (or powered RX) to the lower right connection. Two pages of settings on the card is also confusing... The loose flap is the first set of settings and the one glued to the programming card is the second set (which is accessed by pushing both left corner switches simultaneously).
Lots of head scratching required but it eventually makes sense...
Sep 18, 2013, 09:16 PM
This one was the first I ordered, (almost 4 wweks ago) 2nd one was from USA warehouse, and got the programing card then. ( with in days)
Sep 19, 2013, 12:02 AM
tom bacsanyi's Avatar
Fyi
The YEP controllers have active freewheeling which is an important advance in esc's. If you missed it, go to this thread and read through it and in particular see post 50 where I attempt to explain active freewheeling.
https://www.rcgroups.com/forums/showt...yep+esc&page=4
I now have some flying time with the regular and HV YEP controllers and the extra flying time is very noticeable. With high power setups much more time is spent at part throttle where active freewheeling makes the biggest difference putting more energy into the motor and less heating of the esc.
Sep 19, 2013, 07:23 AM
Foam addict
4stripes's Avatar
Thanks for the Freewheeling explanation Tom,
One question about programming the YEP. There is the top line of the second set of options that lets you choose Freewheel on/off but it also has Governor off/store etc.
The Gov function is for Heli use (from what I understand) so I definitely select that off, but can the Freewheel be selected on from the same line of options? I can only make one selection per line (or am I doing something wrong)...
Thanks for any input!
Eric
Sep 19, 2013, 10:22 AM
Hi Eric,
you can do more selections per line, for example,
"cut off type, accutype" slow down and lipo
you can also select in the first line on side 2 Freewheel off and Gov. off
the importend thing in programming is, that you can hear a clear beep after hit the enter button.
BR
Reinhard
Sep 19, 2013, 07:13 PM
Foam addict
4stripes's Avatar
Thanks BR Reinhard
Will give it another try.
Cheers Eric
Sep 20, 2013, 11:59 PM
Lt599's Avatar
I purchased one from the US warehouse awhile back but no card was available at that time. I have yet to hook it up, I will order a card but can anyone tell my what the programming is out of the box?
Sep 21, 2013, 01:55 AM
Should do the trick
YEP 120HV ESC OPTO-Coupler SET-UP part 1 (10 min 3 sec)
YEP 120HV Opto Coupler - SETUP part 2 - Card Programming and Gov Store (20 min 39 sec)
Sep 21, 2013, 07:52 AM
Foam addict
4stripes's Avatar
Thanks for the videos CBTL!
Sep 21, 2013, 11:43 AM
Lt599's Avatar
Mark, videos are great Thanks, Greg
Sep 21, 2013, 12:20 PM
Your both most welcome. Still waiting on the first one I bought from HK. Althought, as in my first post they suggested it was in, it has not shipped. Did however "spend " a little time in there chat room this AM. asking where it was.
Sep 21, 2013, 11:56 PM
I flew my first one as shipped (no stock on cards) and it was a reeeaaallll slow acceleration but flew ok. Must come in heli mode. I bought a yge card at 3 times retail and it worked fine. I then finally got a yep card and it appears and works like the yge card. If anybody needs one in a hurry, I could mail it and return it when you get one.
Sep 22, 2013, 08:45 AM
Lee Liddle
Knife Liddle's Avatar
Pgrm Cards in Stock, and Manuals for Opeation and Programing
Here is the program card in stock. There is also a download for the manual (not the easiest "english" to understand, but workable
http://www.himodel.com/electric/LED_...ires_ESCs.html
This page has the Hi Models Ice version of the esc and also has two manuals which show how to program the esc without the card.
http://www.himodel.com/electric/ICE_...0A-ICE_HV.html
Sold NIB Hobbyking YEP 120A HV ESC xzd Aircraft - Electric - Power Systems (FS/W) 3 May 29, 2013 11:24 PM
Sold NIB Hobbyking YEP 120A HV ESC $100 shipped xzd Aircraft - Electric - Power Systems (FS/W) 0 Mar 17, 2013 08:08 PM
HET Mig 15 kit for NIB CC 120A HV esc Elec 1800 Non R/C Items (FS/W) 1 Mar 09, 2013 08:34 PM
Sold nip castle ice2 120a hv esc w/ free cc neck strap ohsnap Aircraft - Electric - Power Systems (FS/W) 0 Feb 13, 2013 01:50 AM
Discussion Hobbywing HV 120a/TURNIGY K-Force 120A-HV OPTO 5-12S Brushless ESC Samjet Electric Ducted Fan Jet Talk 11 Feb 17, 2011 01:46 PM
