Jan 10, 2020, 07:47 PM
Hi,
For laminating DTF can minwax polyurethane be used?
Originally Posted by boa2110
Top and bottom. Removed the paper and laminated with Gorilla glue. One wing did not come out flat so I sprayed on a 50/50 mix ammonia and water and let it set. Used hair spray to seal the balsa.
On maiden it seemed to be too light. Could not get much height on launch.
Sent from my iPad using Tapatalk
Jan 10, 2020, 08:18 PM
Originally Posted by dropout
Hi,
I have never tried minwax.
Rebuilt 1.5m AUW 140g.
Jan 30, 2020, 12:26 PM
Maiden flight.
foam DLG (1 min 42 sec)
Feb 07, 2020, 01:14 PM
Found some colored foamboard
Feb 07, 2020, 06:00 PM
sparrow1's Avatar
Kind of wondered when you would find it
Feb 07, 2020, 10:39 PM
I did try the black color before but didn't like how the paper stayed on. This one does seem to adhere better and the white side paper came off easy.
Latest blog entry: DLG builds
Feb 08, 2020, 12:51 PM
Added 18g of lead ballast. Flies fine even after crashing on the second launch.
1.5m (4 min 4 sec)
Feb 09, 2020, 04:58 PM
Another superb effort, looks marvelous
Feb 09, 2020, 06:08 PM
New wing. Single sheet foam with 1/32 balsa.
I can't relate that info to the picture
It appears to be solid balsa that's been shaped with a foam le.
Some of the fun following this thread is trying to figure out what you are actually doing :-)
Feb 09, 2020, 07:21 PM
I formed the foam then laminated with the balsa.
Feb 10, 2020, 02:21 PM
I see thank you !
Feb 15, 2020, 03:35 PM
my second orange DLG. The foam board is only 28" long so it is a little shorter than 1.5m. AUW 152g.
foamboard DLG (4 min 12 sec)
Feb 15, 2020, 11:01 PM
a.k.a. Bob Parks
bbbp's Avatar
Excellent plane & flight! Love the orange & white.
It needs a black racing stripe on the bottom of the wing for orientation!
BP
Feb 18, 2020, 03:31 PM
My third Orange DLG build. Maiden flight.
56" foam DLG (2 min 4 sec)
Second flight.
1 33 (2 min 19 sec)
Feb 19, 2020, 05:33 AM
good grief that's stunning, congrats !
Discussion Dollar Tree Foam Piper Cub roger5005 Foamies (Scratchbuilt) 1 Apr 09, 2013 05:43 PM
Question Dollar Store Foam? How well does it work? cessna20122013 Foamies (Scratchbuilt) 5 Feb 17, 2013 11:33 AM
Discussion Dollar Tree Foam paint and tape. Pyrofan Electric Plane Talk 4 Jan 25, 2013 12:00 AM
Help! dollar tree foam trainer plans needed microairman1 Foamies (Scratchbuilt) 15 Jan 22, 2013 05:30 PM
Discussion My first attempt with dollar tree foam board f.a.r.m.e.r Foamies (Scratchbuilt) 5 Jan 20, 2013 01:00 PM
