Jul 15, 2019, 03:15 AM
I am building a couple 1m wings for my next project. Keep it simple and light.
Jul 15, 2019, 04:42 AM
Originally Posted by old4570
I just ordered some FF gliders ( 1 meter ) from BG .
Under $10 USD , ????
What good are they ? ( I dont know )
Maybe ? I wonder about the wings ...
If you mean this one - I'm afraid it's a POS. I bought it to compare it to the Lidl glider, but it's soft, weak and no cheaper. The glider turned up in a plastic bag wrapped in packing tape which severely mangled the tail sections and even with hot water I was unable to bend it back without it breaking - not unrepairable but enough hassle to piss me off so that'll stay on the back burner until I'm bored enough to get around to fixing it. BTW, Lidl gliders are excellent - very strong EPP and convert to RC or slope use very well indeed
Jul 15, 2019, 07:29 AM
old4570's Avatar
Yeah , ordered 2 .. About $8 USD each shipped ...
Lidl Glider ! , can't get one of those .. Cant even get the 600mm Gliders some people enjoy .
The 350 and 480 are really too small .. ( RC'ed them )
I want to see ..... + There are work around's for soft N weak .
Not sure what direction I will take , maybe motor glider ? Will see .....
Jul 18, 2019, 10:11 AM
1m DLG finished today. I used three HK5330 servos and a 1s 150mA battery. AUW 110g.
Latest blog entry: DLG builds
Jul 18, 2019, 10:50 AM
the correct 51%
RocketRonbo's Avatar
boa, what thickness and material are the tail feathers now? Is the stabilizer
/elevator covered with tape or only the just the hinge line and middle for mounting?
Ron
the correct 51%
3/32" found it on post 923... missed it a few times
Jul 18, 2019, 11:39 AM
Ron
On the 1m I used 1/16" balsa uncovered and tape covered area for hot glue mounting.
Maiden flight today. Flies great.
Jul 20, 2019, 11:04 AM
Morning flight before it gets too hot.
1m DLG (3 min 19 sec)
Jul 20, 2019, 11:34 AM
Looking good, boa.
What kind of wing construction techniques are you using these days? Are you still using four pieces of foam, paper off inside of foam, sanded into airfoil, and glued together?
Or have you figured out a new technique?
Jul 20, 2019, 11:54 AM
Originally Posted by aelflyer
Looking good, boa.
Same technique but I am sanding some on the leading edge area before glueing. Only need one strip of foam to cap LE and shape a good airfoil.
Jul 20, 2019, 02:47 PM
skumgummi dave
Thanks for the video Boa.
Jul 27, 2019, 01:06 PM
1m DLG with AR6400 receiver and a 1s 150mA battery. Rudder/Elevator only. AUW 100g.
1m Foam DLG (2 min 16 sec)
Jul 27, 2019, 07:32 PM
skumgummi dave
Looks like you got some lift.
Jul 28, 2019, 12:26 PM
I like looking for lift low. I don't get nervous about damaging my planes.
low thermal (1 min 50 sec)
Jul 28, 2019, 02:04 PM
skumgummi dave
Nice flight!
Discussion Dollar Tree Foam Piper Cub roger5005 Foamies (Scratchbuilt) 1 Apr 09, 2013 05:43 PM
Question Dollar Store Foam? How well does it work? cessna20122013 Foamies (Scratchbuilt) 5 Feb 17, 2013 11:33 AM
Discussion Dollar Tree Foam paint and tape. Pyrofan Electric Plane Talk 4 Jan 25, 2013 12:00 AM
Help! dollar tree foam trainer plans needed microairman1 Foamies (Scratchbuilt) 15 Jan 22, 2013 05:30 PM
Discussion My first attempt with dollar tree foam board f.a.r.m.e.r Foamies (Scratchbuilt) 5 Jan 20, 2013 01:00 PM
