Sep 21, 2021, 10:48 AM
Originally Posted by dingrrcg
Very neat and simple. Is this is a two-layer wing with the servo space only cut into the bottom layer?
Yes, 2 layered and no spar. I did cut into both layers to get the servo flush with the wing.
When I find lift I try to just keep my speed up. Not try to climb but let the thermal do the work.
46" foam DLG (7 min 2 sec)
Sep 23, 2021, 10:32 AM
Lawn Dart Specialist
SixDeuces's Avatar
Can you elaborate on the specifics of this build? This is really exactly what I'd like to get together in the short term. Its simplicity is lovely and the performance speaks for itself.
From your post history, what I gather is the wing is 2-layers of DTFB sandwiched using non-foaming GG. Paper still in place on the outer surfaces. Popsicle stick peg. Correct?
3/32 balsa tails... no film or coating of any kind? Looks like just a hinge in the pics.
I saw one of your builds using a UMX brick. That's brilliant if it works!
On setups with a return spring on the tail surfaces, I've not been able to find reference pics of how that's done. From what I understand, it's just a 0.5mm music wire, but I'm not following how or where it's mounted. (noob question... trying to get up to speed here!)
Sep 23, 2021, 11:27 AM
I like to build simple easy and light. These builds are for easy launching and thermaling. Not built for hard launches, rough landings, or bad weather.
Two layered wing works best for me. Laminated with white Gorilla glue and paper on the outside. I like 1/16' bare balsa for the tail. Tape hinges all around. I find it easier to use 1mm carbon rod to the rudder/elevator. If you like to use a spring then .015"(.38mm) works.
The UMX brick works fine if you have some laying around
1.5m Umx (7 min 55 sec)
Popsicle stick throwing blade sanded thinner works great.
My next wing will have the 5330 servos laminated inside. Should look cleaner.
Sep 23, 2021, 11:53 AM
@Six. For a spring, bend the wire into a square u shape. Then fold the elevator/rudder all the way over like a taco shell, then poke the wire U in, one leg in each side. Some glue might help keeping it in.
How long the mid section of the U is dictate strenght of spring, also depending on wire size. Experiment.
Sep 23, 2021, 12:04 PM
SixDeuces's Avatar
@boa,
Very helpful, thank you.
Are the wings glued directly to the shaft with no support?
@ffog, thank you. that helps!
Sep 23, 2021, 12:06 PM
Here ya go man. All you’d ever need to know. I use T springs myself to avoid warping the tail surfaces. Works awesome. C spring is what boa is referring to.
I also use the inserted aluminum tubes on glassed foam tails mentioned there. Works awesome as well.
Sep 23, 2021, 12:07 PM
Yes, just clear packing tape and white GG. I do sand the wing root to match the 6mm carbon tube boom.
Latest blog entry: DLG builds
Sep 23, 2021, 11:31 PM
A straight wing also works. You really just need to experiment.
1.5m foam DLG (2 min 38 sec)
If you get all your material ready you should be able to do a complete build in a day or two.
Sep 24, 2021, 12:18 AM
This has some good info:
Foam Board RC Planes for Newbies! (16 min 22 sec)
Sep 24, 2021, 10:50 AM
Total work time on this last one I did was prob only abut 4 hours. Have to wait on dry times of course. But they are def quick to build overall
Oct 04, 2021, 12:05 PM
Simple foam board DLG are great for finding thermals. I seem to catch one every time.
October 4, 2021 (3 min 19 sec)
Oct 05, 2021, 01:12 PM
New 1.5m 2 layered paper on outside and 5330 servos inside wing. 3ch AUW 127g
Oct 05, 2021, 02:47 PM
Maiden
That was a fast build. Here is the Maiden. Needs more dihedral or just make it poly.
1.5m foam board DLG (3 min 52 sec)
Oct 06, 2021, 09:39 AM
Polyhedral wing now.
Oct 06, 2021, 11:09 AM
October 6, 2021 (3 min 4 sec)
Discussion Dollar Tree Foam Piper Cub roger5005 Foamies (Scratchbuilt) 1 Apr 09, 2013 05:43 PM
Question Dollar Store Foam? How well does it work? cessna20122013 Foamies (Scratchbuilt) 5 Feb 17, 2013 11:33 AM
Discussion Dollar Tree Foam paint and tape. Pyrofan Electric Plane Talk 4 Jan 25, 2013 12:00 AM
Help! dollar tree foam trainer plans needed microairman1 Foamies (Scratchbuilt) 15 Jan 22, 2013 05:30 PM
Discussion My first attempt with dollar tree foam board f.a.r.m.e.r Foamies (Scratchbuilt) 5 Jan 20, 2013 01:00 PM
