Dollar foam DLG
I know this will never be equivalent to a high end DLG, BUT!
I made my first quick dollar foam board DLG and it worked from what I was told it was impossible and would not withstand the launch force (I am new to DLG) it may not withstand someone better at launching. Anyways V2 coming soon and I hope it might get more people building It's 360 g and I know I can get that way down (it's half hot glue) It's 1.5 m and uses pull springs
Could you imagine a DLG like the Radian in construction!!!
It could be a super cheap way for guys to join our ranks. We could have cheap one design contests! DLG combat!! and the list goes on and on of cool things a foam DLG could bring to us.... Keep the idea going. hopefully someone will come up with a marketable solution or home built option. Best of luck. Frank |
This reminds me of the foam meat tray free flight gliders I used to build with my son some years ago. We even made a few DL versions. He still talks about those gliders. Loads of fun and always beats watching the same TV show over and over. I'd love to see some close up pics of your build. Thanks for sharing.
Mark |
Build video
This is the video from flite test that I used for my building technique I roughly copied the mimi dlg design but added ailrons and reduced the dihedral I will post pictures soon |
Excellent! I love to see people come up with affordable solutions. I'd also like to see some photos or drawings of your creation. What's she weigh? Wing loading?. Curious how you did the tail boom....built up with the foamboard, or a composite tube of some sort? I use the $4 carbon arrow shafts from WalMart for my 40" foam DLGs.
When people ask how to get into DLGs affordably, the typical answer is "get yourself some one hundred dollar bills and buy a 1.5m composite plane, anything less will turn you off to the hobby." I disagree. A well designed inexpensive DLG will open your eyes to what's possible. A gateway drug to DLG addiction ![]() |
Reason: pssst...hey kid, wanna try one of these?
What a unique design for a dlg!
I have never tried to build a foam board plane. For the tail edges and the aileron trailing edge, could you use the video''s trick of beveling the edge of the foam, with a bit of overhanging paper and pinch those edges to a sharper shape? BP |
What a clever design, i can easily see some places to shave off a little weight. 1/16 balsa tail feathers maybe and a more stream lined pod but hey all in all i love it for what its designed for . i hope this sparks off some interest to experiment with more ideas for the ultimate go build yourself a DLG today with cheap available materials. lets keep this idea going . Great job and thanks for posting the photos
Most excellent - I'm a fairly prolific foamboard builder and I've always thought about building a glider but I've not come anywhere near your success - that video is impressive!
OozyToast,
Congratulations on your DLG is how it starts. One tip I give to your DLG v2, is cut with a wing profile AG45. Here in Brazil built several DLG's for their own use, and low cost. My wings kfm2 always remained very weak, lasted a few days. (laughs) My best results were with clipped wings in hot wire, durability and performance is good, even covered with tape. I did the first gliders, fixed all the electronics on the fishing rod. I'll leave some of the gliders I did, can be of help to gather ideas for your v2. Alexandre Brazil. KFM-2 ![]() Below were all built with airfoil Ag45 ![]() ![]() ![]() ![]() |
Thread Tools | |
Similar Threads | |||||
Discussion | Dollar Tree Foam Piper Cub | roger5005 | Foamies (Scratchbuilt) | 1 | Apr 09, 2013 05:43 PM |
Question | Dollar Store Foam? How well does it work? | cessna20122013 | Foamies (Scratchbuilt) | 5 | Feb 17, 2013 11:33 AM |
Discussion | Dollar Tree Foam paint and tape. | Pyrofan | Electric Plane Talk | 4 | Jan 25, 2013 12:00 AM |
Help! | dollar tree foam trainer plans needed | microairman1 | Foamies (Scratchbuilt) | 15 | Jan 22, 2013 05:30 PM |
Discussion | My first attempt with dollar tree foam board | f.a.r.m.e.r | Foamies (Scratchbuilt) | 5 | Jan 20, 2013 01:00 PM |
