Oct 26, 2018, 10:41 PM
Great paint job! Nice build. Hope to see it fly next season.
Phil
Oct 27, 2018, 09:34 AM
Classic jets rule
AIR SALLY's Avatar
Nice paint job.....should be easy to see.
Oct 28, 2018, 08:43 AM
Thank you for compliments . Is there a vendor that sells cockpit kits
for the F-86?
Jan 31, 2019, 08:05 PM
Semi retired now and finally have time to do some building. Lot of reading over the years on this forum but very little posting. Plan to start sharing
my builds on regular basis. F-86 coming along nice. My son applied the clear coat and it turned out beautiful. Decided to go with no duct work.
Cut off a short extension and glued on to just clear nose gear. Hitec 82mg servos. Pushrods are solid 1/16 wire and are slop free. Rudder servo is
installed in vertical stab. Picked up a Jeti 12 channel assist receiver and plan to try out the gyro. I have a BVM F-86 started and plan on tracing the
interior kit and scaling down the parts to fit this F-86. Weekend plans are to install servos and landing gear in wing .
Feb 01, 2019, 01:14 AM
Classic jets rule
AIR SALLY's Avatar
Looks good ...needs a inlet lip if not using a duct. Ck with Gary at Efflux RC he may have a inlet ring that will fit.
Feb 01, 2019, 02:01 PM
2019 EDF Jet Jam June 13-16
Robert Belluomini's Avatar
You really should use full ducting in that model!
Feb 01, 2019, 05:02 PM
Classic jets rule
AIR SALLY's Avatar
Larry had a plug for the f-86 with the 2 piece nose.(fuse and inlet lip) Brent made it for his when he had a wemo 90mm in his.
Feb 01, 2019, 05:04 PM
Classic jets rule
AIR SALLY's Avatar
Some rolled fiberglass sheet might work to go from whats there to the fan .
Feb 01, 2019, 05:58 PM
I have a plug made for the intake duct. Plan on flying first with no duct work , then install the intake duct and see what the difference is.
My first lay up was to heavy so I cut it up and tacked glued on what you see in picture. First time ever for this and was a learning experience.
Next layup will try light weight cloth and less epoxy resin.
Feb 02, 2019, 12:26 AM
Classic jets rule
AIR SALLY's Avatar
I have made a lot of ducts (several hundred) i would use one layer of 9oz fiberglass cloth(or 5.8 oz C/F) for a high powered 90mm fan. One layer that is cut out of the cloth on a 45 degree angle. Should only take 1.5 oz of resin,2 at the most.
Feb 02, 2019, 06:47 AM
Thanks for the info. I used 2 layers of 6 oz and 3 oz plus of resin.
Feb 02, 2019, 12:25 PM
Classic jets rule
AIR SALLY's Avatar
A one layer 9oz is good, you can add a wrap of C/F tow in the middle if needed. You only need it wet enough to fill the weave to the point that there are no pinholes. You should not have wet puddles on the glass.
Mar 23, 2019, 08:04 PM
Mounted switch and cut my intake in half. I cut two rings for the intakes and glued onto each half.
Four magnets to hold in place. Batteries will fit alongside duct work. Remove intake duct to install
batteries . Pilot is Motion RC pilot for their F-86. Ordered canopy and with interior and cut it up to fit
my bird. Need to do final programming on radio, mount batteries and c/g and she ready for test flight !
Mar 23, 2019, 09:39 PM
Classic jets rule
AIR SALLY's Avatar
Nice ! Make sure your RX works with all that C/F in there.
Mar 30, 2019, 09:39 AM
Nice paint scheme.
Sold *NEW* JHH F-86 kit $375 shipped-Payment plan inpieces Aircraft - Electric - Jets (FS/W) 3 Dec 07, 2013 10:23 AM
For Sale REDUCED $400 shipped *NEW* JHH F-86 kit, retracts, fan inpieces Aircraft - Electric - Jets (FS/W) 6 Mar 13, 2013 01:11 PM
Sold NIB JHH F-86 Kit billdoh310 Aircraft - Fuel - Jets (FS/W) 9 Jan 27, 2013 01:45 PM
Sold JHH Saber F-86 Ducted Fan. AMA EXPO Robert-CSD Aircraft - Fuel - Jets (FS/W) 2 Jan 11, 2013 08:37 PM
Sold JHH F-86 EDF project for sale bruff Aircraft - Electric - Airplanes (FS/W) 9 Jun 23, 2005 08:19 PM
