AC10 Gyroplane (Made in China). - Page 28 - RC Groups
May 02, 2017, 07:28 PM
Got the reply from Aliexpress about the replacement CF rotor blades; it is two blades....a pair.....as shown on the picture.
New question; I have a three blade rotor head from a gyro this same size........if I can easily swap heads for the stock two blade, will the stock AC-10 controls still work OK with three blades ?
May 03, 2017, 02:01 AM
britinoz's Avatar
G'day Tim
Well you and I both may be out of luck mate...I have paid for it..about eight days ago....but for some reason it has not been sent yet. I also thought that it was a reasonable price at AUD $ 58.00.
Buy the time I could get those bits from various suppliers plus freight ..I'm sure it would come out a lot more.
Hi Jim
Iv'e seen footage on you tube of this model flying on three and four blade heads...although I don't think that any were very successful.
The AC-10 that I am flying although a little smaller than the H'king machine is set up for three blades...and that is a very good flying machine.
Chris...
May 04, 2017, 12:42 PM
OK, I ordered the blades from the part of AliExpress with the free shipping. Started checking other RC items and you can easily get lost like Banggood.
May 05, 2017, 12:54 AM
britinoz's Avatar
Finally Prerotor unit shipped from Ali not very Express.
Chris...
May 06, 2017, 12:38 AM
I found my 3-blade rotor head. Looks like an acceptable switch to give lower blade loading. I want to use the AC-10 mast and control elevon links. Unscrewed the single small screw on the stock 't' head and tried gently to pull it off the shaft.........didn't budge. Has anyone found the technique to remove the 'T' head.
May 07, 2017, 08:45 AM
That's odd, once that head locking screw is off you should be able to pull the head right off. Try heat gun or hair dryer on the head and pull with cloth covered.
You may want to squirt some WD40 onto the shaft where it goes onto the head.
The clip below at 1:48 shows that nothing else held it in place except that little screw.
https://www.aliexpress.com/item/Uniq...3-36ada4379ae6
May 07, 2017, 10:01 PM
britinoz's Avatar
Now this is a strange one.
I ordered a prerotator assembly a few days ago for AUD $58.00 and it has been shipped.
I looked at the Aliexpress site again today and saw the same item for AUD $47.91 ...so I ordered another one (spare) but found it finally worked out to cost only AUD36.33 including free freight.....How the hell can that work out...So Tim may be ...you should give it a go ..and hit there discount buttons.
Chris...
May 10, 2017, 12:34 PM
The Tee head is off; put a couple drops of Marvel Oil on it and let it sit a couple days. Now to modify the tri-blade head to fit the shaft and the small hole with a steel pin. No hurry.....new blades are on a Chinese junk crossing the Pacific....if it doesn't get stuck in the floating plastic cess pools.
May 27, 2017, 01:12 PM
The new pair of blades arrived in the mail.........they look even better than the blades that came with the AC-10.
The rotor head now has a three blade holder on top. Ready to balance and mount the blades.
Replaced the small screw that actually holds the head to the mast and am using a spring steel pin. As an engineer, I won't be surprised if the head and body part company in flight.........that's a lot of concentrated load on that pin and shaft.........and as the blades go round each creates a pulsating loading.
Jun 02, 2017, 03:33 AM
Jockadopolus's Avatar
French review of the model use Google translate
https://jeancousin4923.wordpress.com...e-uniquemodel/
Jun 03, 2017, 12:51 AM
britinoz's Avatar
Thanks Joe "almost" makes me want to buy one...after the model had landed ... I'm pretty sure that the prerotor was still running ??
Chris...
Jun 03, 2017, 05:21 PM
FPV'r
ror1's Avatar
Chris...
I think it is running as well...
Jun 03, 2017, 10:35 PM
Here are pictures of the motor support I added. I am installing a Hobby King Rx with the built-in stabilizer.
Jun 04, 2017, 06:35 PM
Nice modification. What size of the ball bearing you use?
I'd drill some holes around the BB and more underneath to help with the air flow.
Thanks for sharing.
Jul 02, 2017, 09:08 PM
Looking for comments after today's 2 attempts; My AC-10 has a 3-blade rotor with the CF blades. The prop blast barely helped spin up the rotor. Added a 1/32" shim to increase the blade rotation angle.
first attempt got light and started to lift up but I throttled down to avoid the barrier weeds. 2nd attempt lifted up and immediately rolled left 90 degrees and did a knife edge 120degree turn at waist high. Dropped the throttle to off and the AC-10 immediately rolled right and flew straight for a perfect landing.
The neutral rotor is set level with the up pitch .
I am going to add more shim to increase the blade spin angle more.
The rolling ground track is straight.
Nothing broken in the two attempts.
