Mar 07, 2015, 03:59 PM
Yin & Yang
Liberty10's Avatar
Yes it is in DSMX mode but the servos are not moving correctly or at all on 2,3,4, & 6. Going to check the throttle in a second
EDIT: No joy on the throttle either. It turns the motor over but about a third up it drops back down to idle.
Right now I'm stumped without your help Jim.
I was going to try this on a 60 size plane before putting it in 35cc airframe. Guess not today
Mar 07, 2015, 10:13 PM
Originally Posted by keither1984
So your saying in order to get it to bind in dsmx mode hook up a rx and sat bind and then unhook the rx and leave the sat and it should be in dsmx mode.
Yes, that is all that is required. You can do the same thing with DSM/DSM2.
Mar 07, 2015, 10:15 PM
I am going to have to look at a DSMX setup to figure out what the issue is.
Mar 07, 2015, 11:14 PM
Yin & Yang
Liberty10's Avatar
Jim,
I just rebound it direct with the x10 and the channels align and servo action is correct. I just don't want to use DSM2 anymore. Def appreciate your looking for a work around. I'll keep an eye out for the update
Mar 07, 2015, 11:46 PM
What I'm confused about is that I didn't know Spektrum had any kind of serial protocol like Futaba s.bus or JR XBus.
Mar 07, 2015, 11:53 PM
The satellite receivers output a serial protocol, originally to talk the main receiver.
Mar 08, 2015, 12:00 AM
One reason I have never moved to Spektrum is I just don't understand the whole satellite thing. I know that part of it is signal diversity, but I knew they weren't just passive antennas but actual electronic devices. I just don't understand why that couldn't be accomplished with a single device like every other radio manufacturer.
Mar 08, 2015, 11:58 AM
Satellites provide spacial diversity, just like multiple antennas do. We made a satellite receiver at the request of Graupner, but when range testing proved that the only thing they provided was redundancy in case the main receiver failed (which is highly unlikely), they were discontinued,
Mar 08, 2015, 12:56 PM
So is it also the case that if a Spektrum main RX fails that the satellite(s) can still allow the radio to function?
Mar 08, 2015, 11:40 PM
Their main Rx also drives the servos, so if it fails the servos stop working.
Mar 09, 2015, 01:16 PM
Jim,
What DSMX receiver and satellite receiver model number are you using that had the problem? I received a report from another DSMX user that had no problems with an AR8000 using a SPM9645 satellite receiver (after binding it first using the AR8000).
Mar 09, 2015, 02:05 PM
Yin & Yang
Liberty10's Avatar
I'll have to check the sat model number but the RX was AR8000 that I bound it to. I'm pretty sure it's the one that came with the AR8000 though.
EDIT: I just looked the satelites up on the Spektrum web site and it has to be the AR9645 since it's the only one listed for DSMX. I know it looks exactly like this because I peeled some sticky gel tape off it last night.
Mar 09, 2015, 02:14 PM
Yin & Yang
Liberty10's Avatar
I'm not sure how I could possibly been doing something wrong. It's not like there are multiple ways to bind the rx.
I'll go ahead and rebind it for the 4th time to the AR8000 this evening and see if it works again.
Mar 09, 2015, 02:51 PM
Banzai Institute
buckaroo's Avatar
+1 on that.
I would be afraid to fly with just one receiver if they say 2 is better. Kinda hokey if you ask me.
Dean
Mar 09, 2015, 03:09 PM
Yin & Yang
Liberty10's Avatar
Originally Posted by buckaroo
+1 on that.
Dean
So your padding your post count here right? Certainly you didn't post that because you thought someone wanted to hear your..... opinion.
Discussion Channel expander question Engineer Bill Radios 11 Nov 24, 2020 12:21 AM
Sold Parkzone X10 6 channel transmitter Tampatexan Aircraft - General - Radio Equipment (FS/W) 0 Jun 10, 2012 07:15 AM
Sold Berg 5 channel receiver w/ 4 channel expander Fizzy Aircraft - General - Radio Equipment (FS/W) 0 Oct 02, 2008 05:52 PM
