Sep 01, 2020, 04:42 PM
mostly gliders
liukku's Avatar
Originally Posted by JimDrew
ALL of the X10+ v2 units have live active failsafe. The fix in v1.2 was for LED flashes.
Are you performing the live active failsafe correctly? Once the transmitter and receiver are connected, press and HOLD the programming button on the X10+ until the LED starts alternating colors. Once that occurs you have about 7 seconds to move your sticks/knobs/switches to the positions you want them to be during a failsafe condition.
You do NOT update the X10+ firmware using the XDP. You must use the Updater program.
I belive I have done live active failsafe correctly. By the way, do I have to move the sticks / knobs / switches in the meantime LED alternating color flashes?? Is it not possible to set lever positions in advance before the LED light flashes? Could it be that it's because the X10 is not up to date with the latest software that the live active failsafe fails?
Then I misunderstood how to update the X10, where can I find the Updater program?
/Ville
Sep 01, 2020, 09:57 PM
Originally Posted by liukku
I belive I have done live active failsafe correctly. By the way, do I have to move the sticks / knobs / switches in the meantime LED alternating color flashes??"
Yes. The live active failsafe is enabled WHILE the LED is alternating colors, which occurs for about 7 seconds. You have that time to move the sticks to where you want them. Once the LED stops alternating colors, the positions that you set will then be "locked' into memory. You must HOLD everything exactly where you want it until the LED stops alternating colors.
No! The positions are stored in memory when the LED goes from alternating colors back to solid green. Just moving the sticks to some position and then moving them back before the LED has gone back to solid green is going to store the positions of where they were move to when the LED changes back to solid green.
No. ALL X10+ boards have live active failsafe from the very 1st version of firmware.
/Ville
On our website, under Downloads->firmware updates:
https://www.xtremepowersystems.net/x...are%20Upgrades
Or in the firmware updates thread here:
https://www.rcgroups.com/forums/show...irmware/page35
Question X10+ Expander with Nano - customer comments please... JimDrew Xtreme Power Systems 48 Sep 22, 2013 09:54 PM
Discussion Channel expander question Engineer Bill Xtreme Power Systems 9 Jun 24, 2013 05:08 PM
Sold Parkzone X10 6 channel transmitter Tampatexan Aircraft - General - Radio Equipment (FS/W) 0 Jun 10, 2012 07:15 AM
Sold Berg 5 channel receiver w/ 4 channel expander Fizzy Aircraft - General - Radio Equipment (FS/W) 0 Oct 02, 2008 05:52 PM
