Aug 10, 2019, 11:35 AM
CZC landing gear adapter?
Anyone making an adapter (3d printer) to adapter the v2 landing gear to the v1 CZC?
Aug 10, 2019, 12:31 PM
Kavan wheels and the hngar 9 landing gear update
Originally Posted by doug.wagner
I've finished mounting the landing gear, and I've got to say I am very happy with the results!
To start with, I am thrilled with the quality of construction of Hangar 9's gear. The only imperfection I found, was that one of the tubular steel pivot points was 1 mm longer than the other 3...no big deal!
The question of how to mount the gear to the fuselage was answered when thrashing around the workshop, searching for the right piece of steel channel to lay into the fuse, I noticed my collection of odd toggle bolts. The spring loaded, steel butterflies at the ends, looked amazingly like the mounts that Hangar 9 sells for its Carbon Cub.
If I cut the fuse up to mount my gear, I'd have to come up with a new way to mount the floats, and I do like flying on floats!
I decided to leave the fuse intact, and make my new mounts removable.
After much measuring, eyeballing and test fitting, I drilled holes in my new found brackets, and lined the ends of the original gear's slot with some of my wife's cling wrap.
I smeared the insides of these pockets with a little petroleum jelly on a Q-tip, and packed in some JB Weld "Water Weld" epoxy putty. I pressed the brackets onto the putty, and cleaned up the extra that oozed out.
That putty sticks so well to the steel that it might be enough to hold for some people's landings, but certainly not enough for mine!
When hardened, I pulled the brackets out of their sockets, cleaned them up, and drilled a screw hole through, to hold them in place.
These, and the rear brackets will be the weak point in a badddd landing. I didn't use the ones with the heaviest gauge steel, and the screws holding them in place are only as strong as the rather thin plastic that they are screwed into.
The included axles weren't long enough to accommodate my Kavans, so I cut up a nail that was the perfect diameter. The head of the nail saves having to use a retaining collar!
I left the crosshatch pattern on the head of the nail for a laugh.
I can't wait till it warms up enough to test the new gear.
Can someone lead me to the right post or tell me how the were able to get the Kavan wheels to work on the Hangar 9 cub articulated landing gear? I think I bought the last pair of kavan wheels in the US and the inside diameter on the axel adapters included in the bag are still larger than the axel diameter. Is there a size of brass tubing that will act as a shim?
Jim
Aug 17, 2019, 02:18 PM
I read many threads about this Cub. I happened to get one from a buddy and did read that the OE prop was no good. I could not find a read on what you guys use for a replacement prop for the OE prop and motor. Would appreciate your help god you use one with success. Thanks.
Aug 17, 2019, 02:56 PM
It’s not a bad prop but when I modified mine and installed a larger motor I put an APC electric prop, any electric prop properly sized will do the job.
Aug 17, 2019, 06:22 PM
I hate to do the popular mod job I see here as it is used and pretty beat up but it flies very good when I saw my buddy flying around in circles. Just thought there was the ideal substitute for the OE prop. Might just keep using that. Problem is I heard it soaked up moisture. Maybe a spray varnish would fix that or nothing at all. Thanks for your reply.
Aug 17, 2019, 08:13 PM
Do you have a wooden prop? The OEM is plastic.
Aug 18, 2019, 12:48 AM
If it flies, I can crash it.
rocketsled666's Avatar
Power 60 with a Xoar 16x8.
The stock prop isn't all that bad. They have a similar prop on the Carbon ZT-28 which *is* crappy and almost everyone replaces right away. But I think I flew my Cub on the stock prop and motor until I busted the prop and bent the motor shaft and upgraded. The stock prop did need to be balanced, though. It was way off out of the box. I never flew it with an unbalanced prop, but I suspect the plane would have been noisy as hell at WOT if I hadn't balanced it.
Aug 20, 2019, 02:06 PM
Kavan wheels and E-Flite Carbon Z landing Gear
Originally Posted by Jpmcdo
Can someone lead me to the right post or tell me how they were able to get the Kavan wheels to work on the Hangar 9 cub articulated landing gear? I think I bought the last pair of kavan wheels in the US and the inside diameter on the axel adapters included in the bag are still larger than the axel diameter on the e-flite axel. Is there a size of brass tubing that will act as a shim?
Jim
Since no one responded to my question and since I have solved my dilemma, I thought I would post the solution that worked for me.
I used Albion Alloys round brass tubes. The one that is 4.76MM X 0.35MM fits inside the Kavon wheels and around the E-flite carbon Z cub landing gear - https://www.horizonhobby.com/landing...cc-p-han506517
Th brand of tube shouldn't matter, but that is what my local hobby shop carries.
Aug 20, 2019, 02:18 PM
I am not a robot
Sideslip's Avatar
Glad you got it solved. I really didn't know the answer, as I suspect many others did not.
Good information too,
Bert
EDIT; Please post some photos when you have it mounted.
Sep 23, 2019, 03:43 PM
I Fly!
jrtubb's Avatar
Has anyone tried putting the new Carbon-Z Cub Gear on the original Cub? Also I was thinking of tryin those twist on wing screws from the new cub too.
Sep 23, 2019, 08:31 PM
Acft Attn Deficit Disorder
Cubcrazy's Avatar
V2 gear will not work on v1 Cub. (I have both)
The plastic plate on the bottom of the v2 is different. You would have to modify the structure and add some mounting fixtures to make it work.
The thumb screws will work on the v2. There is nothing special about them aside from having a molded plastic "gas cap" to allow finger tightening.
V2 wings will also work on v1 and vice versa.
Latest blog entry: From the CC Paint Shop
Sep 25, 2019, 07:17 PM
"Fly Low, Fly Fast, Turn Left"
DanDaMan007's Avatar
They were collecting moisture really easily and would go in and out of balance.
Latest blog entry: Miss Foxy Lady eBuild
Oct 08, 2019, 06:43 AM
I am not a robot
Sideslip's Avatar
Splash covers needed
While I realize that it they aren't mandatory, I'd like to get a set of the splash covers that go on the bottom of the fuselage. I've had several different CZCs over the years. A couple of years ago I sold the fuse that had the float flying splash covers on the bottom.
I'd like to get another set without having to purchase a complete float set. So if any of you happen to have a set laying around the shop and you wouldn't mind parting with them please let me know.
Bert
New Product E-flite Carbon-Z Splendor BNF ChuckTseeker Sport Planes 3681 Sep 16, 2019 09:38 AM
For Sale E-FLITE BL25 POWER 25 BRUSHLESS MOTOR CARBON-Z $57 shipped 3drcparts Aircraft - Electric - Power Systems (FS/W) 4 Apr 08, 2013 12:16 AM
For Sale NIB E-Flite Carbon-Z Yak Servo Cobra68 Aircraft - General - Radio Equipment (FS/W) 0 Jan 27, 2013 06:02 PM
Sold E-flite Carbon-Z Yak 54 PNP *LPU* jjohns51 Aircraft - Electric - Airplanes (FS/W) 3 Jan 06, 2013 03:37 PM
