This thread is privately moderated by Jim.Thompson, who may elect to delete unwanted replies.
Sep 04, 2013, 06:35 PM
Entropy is happening!
Jim.Thompson's Avatar
Box section EPP fuselage.
I'm planning on putting together a light 1500 mm span EPP plank at our coming Manilla Slope Festival. It will have a PW75 airfoil and I'll cover it with laminating film. This will be my first attempt at using Lam film.
I decided on the spur of the moment to make up trial fuselage using 12mm sheet offcuts from a former EPP wings sliced down using my hot wire.
I cut out the sides using a fibreboard template and laminated 200 gsm uni-carbon to one side of each (to become the inside of the assembly). In hindsight, I would use uni-glass instead due to any 2.4 ghz shielding concerns.
I then cut some more sheet to form the top and bottom of the fuselage and laminated this with 200 gsm uni-glass.
Some formers were made with some carbon strip which I had made some time previously to fit several stations.
The assembly was a bit of a fiddle, and some more thought is needed to get this sorted. But I used some hot glue for the first bottom/side join. Not a good idea, as this caused some sanding problems later on. However, it did provide a good start. The battery pack (4 AA cells) was hot glued into place and well supported as far forward as possible. The remaining side and bottom was glued up using PU glue and spiral wrapped with tape overnight.
I shaped and sanded the corners this morning and the result looks quite presentable! Nice and light and very stiff!
Sep 05, 2013, 06:49 AM
SINK HAPPENS !!!!
EeleyEagle's Avatar
Lam Film
Jim,
Do you have laminating film ? If not I have plenty, just let me know. Your plank is looking good.
Andrew
Sep 05, 2013, 04:07 PM
Yes I have some thanks Andrew.
Discussion Ultimate X3- Va-models full fuselage EPP Aerobatic Bi-plane. rc4u 3D Foamies 71 Dec 04, 2019 09:17 AM
Found 3DHS EPP Extra Fuselage RAlanBoyle Aircraft - Electric - Airplanes (FS/W) 0 Aug 25, 2013 02:41 PM
Cool Epp foamy full fuselage Va-Models Loop. rc4u Parkflyers 2 Jul 05, 2013 10:46 AM
For Sale Sailaire Electric With 4 Section Wing And 2 Section Fuselage carrinsr Aircraft - Sailplanes (FS/W) 3 Aug 14, 2009 01:24 PM
Need P51D fuselage/canopy x-sections Zhack Slope 3 Mar 22, 2004 03:26 AM
