This thread is privately moderated by mutski, who may elect to delete unwanted replies.
Sep 04, 2013, 06:24 PM
mutski
5.8 ghz FPV EasyStar II setup
Here is my current Multiplex EasyStar II FPV setup. Max flight so far was 2.38 miles at 856 feet. The video was getting fuzzy at 2.38 miles, and I had several momentary control signal dropouts on the way home, but at 800 feet there was plenty of time to regain the signal.
Easystar II Parts
Turnigy2836 brushless Outrunner 1200kv $18.68
https://www.hobbyking.com/hobbyking/s...idProduct=7992
Dimension: 28mm x 37mm, 55mm(with shaft)
Weight: 74g (kv1200) (not including connectors)
Diameter of shaft:F4.0mm
Length of front shaft:F19mm
Lamination thickness: .2mm
Magnet type: 45SH
Max performance
Voltage: 3-4S Lipoly
Prop: APC9x6
Thrust: 1100g
Power: 340W
Turnigy Plush 25 amp ESC $20.95
http://www.rcfoam.com/product_info.p...oducts_id=1132
Cont Current: 25A
Burst Current: 35A
BEC Mode: Linear
BEC : 5v / 2A
Lipo Cells: 2-4
NiMH : 5-12
Weight: 22g
Supported motor speed for all TURNIGY ESCs is;
(Maximum): 210000 RPM (2 poles), 70000 RPM (6 poles), 35000 RPM (12 poles)
Turnigy BESC Programming Card $6.95
https://www.hobbyking.com/hobbyking/s...idProduct=2169
EXI S1123 9gm Digital Servos
http://www.nitroplanes.com/exi-servo-s1123.html
Dimensions: 22.6 x 11.4 x 22.2mm
Weight: 9g / 0.32oz
Operating Speed (4.8V no load): 0.12sec/60 degrees
Stall Torque (4.8V): 1.4 kg/cm
Operating Voltage:4.8 Volts
690TVL Ultra WDR Pixim SEAWOLF HD CCTV Mini Camera, PZ0481 $88.50
http://www.securitycamera2000.com/pr...-OSD-Menu.html
3.6 mm Lens OSD
56mm wide, 57mm high, 115g,
12V, <150ma,
1/3 DPS sensor, Min. Illumination 0.1 lux
Immersion 600mw 5.8 ghz Video Transmitter $69.99
http://www.readymaderc.com/store/ind...roducts_id=266
600mW (+28dBm) typical output power
6-25V input voltage, 2S-6S LiPo compatible
Typical power consumption of just 3W at any input voltage
5V power output, ideal for powering cameras
Video, stereo-audio
Composite video input at 1Vpp/75 ohm
7 channels (5740, 5760, 5780, 5800, 5820, 5840, 5860), PLL synthesized
FM Audio/Video Modulation
50 ohm antenna impedance.
Weight: 18-grams.
Size : 50 x 23 x 15 mm.
Requires airflow for cooling, do not mount in an enclosed area
Must be used with an antenna at all times
5.8 GHz SpiroNET Omni RP-SMA Antenna Set (RHCP) $39.99
http://www.readymaderc.com/store/ind...oducts_id=1058
Set includes 3 lobe and 4 lobe skew planar antennas manufactured by Immersion RC.
HobbyKing G-OSD 3 with GPS $37.50
https://www.hobbyking.com/hobbyking/s...PS_Module.html
Weight: Main Board - 5.7g / GPS Module - 11.6g
Dimensions: Main Board - 40x26x6mm / GPS Module - 28x16x8mm
Working Voltage: Main Board - 7~25V / GPS Module - 5V
Programmed with CL-OSD
https://code.google.com/p/cl-osd/
https://www.rcgroups.com/forums/show....php?t=1490446
DORA translates (Spektrum) DSMX receiver output into RSSI signal for OSD/FPV $25.99
http://www.ebay.com/itm/ws/eBayISAPI...ectorid=229466
Lo-Cut Filter (470 microfarad 25V capacitor)
https://www.rcgroups.com/forums/show...7&postcount=14
Ferrite rings in video cable and FPV cam & Vtx power cables
Shielded speaker wire for video connections
Fatshark Dominator Video Glasses $299.99
http://www.readymaderc.com/store/ind...roducts_id=522
Fatshark Dominator 5.8ghz Receiver Module $33.99
http://www.readymaderc.com/store/ind...roducts_id=524
5.8 GHz 3 Turn Helical (Can Be Goggles Mounted) (7 dBic) (IBC) $29.99
http://www.readymaderc.com/store/ind...oducts_id=1089
Frequency range: 5600-5980Mhz
5.8 GHz 5 Turn Helical (Can Be Goggles Mounted) (9.5 dBic) (IBC) $33.99
http://www.readymaderc.com/store/ind...oducts_id=1090
Beam width: 105 degrees
-3db point: 65 degrees
Axial ratio: .82
808#16 Keychain Camera, Lens B $47.99
http://www.ebay.com/itm/380627482427...84.m1439.l2649
Removed battery and connected to spare receiver channel for endless power
Spektrum AR6210 6-Channel DSMX Receiver with remote $69.99
http://www.amainhobbies.com/product_...FeZxQgodfkoADw
Type: Full Range Aircraft Receiver
# of Channels: 6
Modulation: DSM2/DSMX
Band: 2.4GHz
Length: 1.19 in (30.1mm)
Width: 1.03 in (21.6mm)
Height: 0.48 in (12.3mm)
Weight: 0.35 oz (10g)
Voltage Range: 3.59.6V
Antenna Length: Main Rx: 30mm (2); Remote Rx: 30mm (2)
Spektrum Dx6i modified to accept 7dbi patch antenna
Tx mod: https://www.rcgroups.com/forums/show....php?t=1247186
Parts:
http://www.rangevideo.com/index.php/...h-antenna.html
http://www.orbitmicro.com/global/6-u...FYF7Qgodfh4AEQ
Sep 05, 2013, 01:45 AM
For flying out loud!
planemad man's Avatar
your drop outs may have been caused by the fact that the sat rx was so close to the vtx. if you move the sat rx out to one wing tip then you should get much better control range.
ground station: if you kepp you control transmitter away from the vrx then you should also get better video range.
Sep 05, 2013, 07:48 PM
mutski
Thanks planemad man! Good idea, I hadn't thought of it. I have been reluctant to place electronics on the wings because I take it apart and transport in the original box. I might try moving the satellite to the fwd part of the fuse though. I think I also have a video problem because the motor pod shadows the vtx on the return trip. Turning 20 degrees and tacking like a sailboat helps, but it might be nice to mount the vtx on the tail fin to get the antenna higher.
Meanwhile I'm building a second ESII, just ordered EZ-UHF and 1.3 ghz video equipment.
Sep 06, 2013, 01:11 AM
also with the reciver antena and satalites you want all the antenna pointing in diffrent direction as much as you can.
Sep 06, 2013, 05:08 PM
mutski
The rx and satellite antennas are 90 degrees to each other at present. The satellite antennas are wrapped around the fuse so that there is a vertical component too. Maybe better if not wrapped?
Sep 07, 2013, 02:17 AM
i think if the anntennna are curved in use it ruinins the polarization but that is just me thinking out loud
Sep 20, 2013, 10:56 PM
mutski
Curved antenna? Question is moot because I flew into the radio shadow of a hill and did a nose plant from 300 feet. I'm gearing up to build a new ESII with 1.3ghz video and 433mgz control. I needed a good excuse to upgrade anyway. I do miss the crunched one though.
Sep 21, 2013, 01:01 AM
oh it looks like the antenna for the sat rx has been curved
Oct 01, 2013, 02:51 PM
Hi Mutski,I have just stumbled across this thread in an attempt to find out some info on the HK g-osd 3 that I can't get to work.
Please can you show me the way to wire it up to the Immersion 600mw vtx and a sony 450 line camera.
The instructions are confusing to a newbies first venture into OSD use.
Please excuse me if I'm in the wrong place to ask, it's just I see you use the same equipment!
P.s I've just done the same as you, flew my Easyfly st330 into a dead zone 2km along a beach but the failsafe must have worked since it landed fairly softly into the rocks!
For Sale Complete 5.8 GHz FPV Setup for Icon A5 maso2520 FPV Equipment (FS/W) 1 Aug 22, 2013 07:09 PM
For Sale 4 Brand New 5.8 Ghz Fpv Antennas Skew Planar Polarized Forong Distance Fpv iwcai Aircraft - Electric - Multirotor (FS/W) 1 Jul 31, 2013 11:22 PM
Sold 5.8 Ghz FPV setup FatShark Doms, Immersion RC ETC! BriGuy82 FPV Equipment (FS/W) 6 Apr 24, 2013 07:23 PM
Discussion 5.8 GHz 200-900mw + Fatshark goggles: Is this a good first FPV setup? VuzeDroid FPV Talk 18 Aug 14, 2012 04:21 AM
Found 5.8 GHz FPV setup (w/ Fatshark if possible) MCrites FPV Equipment (FS/W) 2 Mar 26, 2012 12:02 PM
