Sep 03, 2013, 11:56 AM
Ad eos qui nesciunt crepitus
Old_Pilot's Avatar
Build Log
BBCC 3 - 48" Hawker Tempest Mk-1 - Old_Pilot
My entry for the BBCC 3 is a 48" Hawker Tempest Mk-1 (Based on the 1944 Fighter Glider). I'm adding a power plant and undercarriage. Working on the drawings now.
O_P
For all you guys that want a look at the "as-built" drawings, and don't want to page through this mess, they're up on OuterZone......Hawker Tempest Mk-1
Sep 03, 2013, 12:12 PM
Old_Pilot's Avatar
Hawker Tempest Mk-1
Tempest Mk I : Prototype fitted with the Napier Sabre IV piston engine with oil coolers and radiators placed in the wing to reduce drag, one aircraft.
From Wiki:
The new design was finalised by October 1941 and the Air Ministry issued specification F.10/41 that had been written to fit the aircraft. A contract for two prototypes of the "Typhoon Mark II" was issued in November, and the new fighter was renamed "Tempest" in January 1942.[2] The problems experienced with delivery of engines finally led the Air Ministry to ask for six prototypes with different engines so that if a delay hit one engine an alternative would be available. This resulted in a single Mk.I, HM599, with a Sabre IV, two Mk.IIs (LA602 and LA607) with the Centaurus IV, a Mk.III (LA610) with a Griffon IIB, a Mk.IV (LA614) with a Griffon 61, and the Mk.V (HM595) with the Sabre II.[9]
First prototype Tempest II LA602, again with the small tail unit.
The first Tempest prototype, the Mark V HM595, was first flown by Philip Lucas from Langley on 2 September 1942. This aircraft retained the Typhoon's framed canopy, car-style door, powered by a Sabre II engine, and fitted with the "chin" radiator, similar to that of the Typhoon. It was quickly fitted with the same bubble canopy fitted to Typhoons, and a modified fin that almost doubled the vertical tail surface area. The horizontal tailplanes and elevators were also increased in span and chord (these were also fitted to late production Typhoons.)
Test pilots found the Tempest a great improvement over the Typhoon in performance; in February 1943 the pilots from the A&AEE at Boscombe Down reported that they were impressed by "a manoeuvrable and pleasant aircraft to fly with no major handling faults". The Air Ministry had already ordered 400 Tempests in August but production of the new Sabre IV engine ran into protracted problems and delays. The second prototype, the "Tempest Mark I" with the Sabre IV did not fly until 24 February 1943. This prototype also had at first the older Typhoon cockpit structure and vertical tailplane. Elimination of the "chin" radiator did much to improve performance and the Tempest Mark I was the fastest aircraft Hawker had built to that time, attaining a speed of 466 mph (750 km/h).Continual problems with the Sabre IV meant that only one Mark I (HM599) was built; consequently, Hawker went into production with the Sabre II engined "Tempest V", with the first rolling off the production line on 21 June 1943.
Sep 03, 2013, 12:42 PM
Old_Pilot's Avatar
Pic's of a 1/32 static Tempest Mk-1
Found these on the web
Latest blog entry: 40" Hawker Tempest Mk-1 Foamie
Sep 03, 2013, 07:21 PM
Old_Pilot's Avatar
Some drawings of the Mk-1 and others
Found these too
Sep 03, 2013, 08:17 PM
Scale Builder
Excellent choice of subject O_P. There are a number of the Hawker prototype one-offs that are very interesting subjects and I am a huge fan of the prototype paint schemes. Maybe it's because I can see Yellow better than just about any other color! Looking forward to your build.
Sep 03, 2013, 10:11 PM
**neons**'s Avatar
The Tempest is a nice plane. I like the Typhoon a lot too. That big cowling can hold a lot of equipment. Nice plans also. So many planes and so little time.
**Neons** Bob
Sep 04, 2013, 05:52 AM
Old_Pilot's Avatar
Tempest Mk-1 Design Notes
Preliminary numbers.....
Estimated hardware weight: ~ 16 oz
Estimated Aircraft weight: ~12 oz
Wing Area: ~ 370 sq in (2.57 sq ft)
Wing Loading: ~ 11 oz/sq ft.
It looks like I'm going to have to look for very high strength, very low density building materials...commonly called "Nonexistium", which is one element past "Unobtainium" on the periodic table.
So far, I've increased the dihedral a bit, reduced the cross-section of the fuselage, and will probably increase the chord and span....Looking at a PW51 airfoil.
Haven't run the Tail Volumn/MAC calc's yet, so all this might change a bit
Considering making the wing in one piece and cut the fuselage keel to fit the top of the airfoil.
Since this is my first electric powered aircraft, will cooling vents be required ?
**neons* Bob.......How much do you charge for hangar space rent ?
Sep 04, 2013, 08:38 AM
**neons**'s Avatar
OP,
I would say my space is almost full here. It is a garage loaded with 4 MCycles, a big 50's car, 50+ planes hanging, and 2 lathes and welding equip in there. It looks like a big boys toy room there. I am almost constricted to build more planes now. My tiny build slab is still there but hard to move around now. I snuck my 1/4 scale Neiuport 28 upstairs until this next build season so I can finish her. I also have a closet full of planes up there also. Wow! Looks like you are out off luck renting space. I still have my 61' wing CL stunter Hein Tony hanging on the wall. The plane was scratch built in a cellar right after I got married. It has an old Barker 60 in it from 1945. The plane flew nice.
**Neons** Bob
Sep 04, 2013, 07:30 PM
AMA 986339 FCC KB5LAM/4
davidterrell80's Avatar
Cooling... I always plan on air moving through the fuselage, past the motor and over the ESC and battery but, unless you fly in 85F and over, you probably will have more than enough cooling with about two postage stamps equivalents of clear area in each former forward of the electronics and out the bird. I usually make the rudder & elevator push rod exit slots slightly oversize so the total area is about one postage stamp and perhaps cut the covering away for one triangle at the aft-bottom end.
Sep 05, 2013, 05:22 AM
Old_Pilot's Avatar
Cooling and other considerations
Thanks David.....
Here's what I plan to do:
The fuselage forward of the "firewall" becomes a cowling with front completely open, for two reasons. One, motor access; two, inlet cooling air. Couldn't figure out a good way to use the Mk-1's wing shoulder radiators for inlet air. They'll just be window dressing.
Firewall has vent holes drilled between engine mounting holes at 45 deg opposed. The rest of the bulkheads will be open in the center.
I'll use the push rod exits and tail wheel opening for "exhaust" air.
Thanks again
Sep 06, 2013, 08:34 AM
Old_Pilot's Avatar
Preliminary 3-view
First blush at the 3-view.....and the finished aircraft.so y'all don't have to page through to see the finished bird
Sep 06, 2013, 08:46 AM
Old_Pilot's Avatar
Mk-1 Fuselage
Question:
It looks to me like the cross-sections of the Mk-1's fuselage have a radiused
top and bottom with straight sides at the tangents. The pictures of the 1/32
static Mk-1 suggest this former.
See attached......Mk-1 is in the upper let hand corner
Fighter Glider had elliptical formers. The pictures of the 1943 prototype Mk-1 suggest an
elliptical former....
Or are they a cross between the radiused upper half and an elliptical bottom half.....kinda like a P-47 thunderbolt.
Other variants of the Tempest show circular cross sections......
Anyone know which is which ? Any guidance would be appreciated.
O_P
Sep 06, 2013, 05:48 PM
**neons**'s Avatar
Great looking plane. It sure has plenty of formers. It should keep you busy for some time. The finish plane will look good. There is plenty of wing area also.
**Neons** Bob
Sep 06, 2013, 08:26 PM
There are some scale views here.
They vote for an oval aft fuselage cross-section. Here's a Mk 2, for example:
Sep 12, 2013, 05:53 AM
Old_Pilot's Avatar
First iteration of the drawings
Here's the first pass at the drawings
Discussion 48" span Hawker Hurricane MK II Lancer31 Electric Warbirds 2 Feb 10, 2013 03:25 PM
Off Site Skyshark RC Hawker Tempest MK-V - 45 (Kit) edygert Aircraft - Fuel - Airplanes (FS/W) 1 Feb 19, 2009 02:50 AM
Build Log Building a large Hawker Tempest Mk 5 thomanie Scale Kit/Scratch Built 127 Nov 08, 2006 03:35 PM
Hawker Tempest Mk II painted (finally) Ron Daniels Scale Kit/Scratch Built 30 Apr 09, 2002 02:58 PM
Hawker Tempest Mk V finally painted Ron Daniels Scale Kit/Scratch Built 6 Apr 01, 2002 12:16 PM
