This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Sep 03, 2013, 03:36 AM
Jack Crossfire's Avatar
Computational requirements
The STM32 can do a 1024 point FFT in 5ms. There's also the unknown matter of computing magnitude, normalizing, making it probably 10ms. At 10 sweeps per second, that gives only 10 FFTs per sweep.
That comes with a 8192 byte tag.
2048 bytes: analog capture window
2048 bytes: imaginary value window
2048 bytes: simultaneous capturing of next window
2048 bytes: normalization table
Then, the 1st 256 samples from each window are stacked on a polar projection. Only the 1st 1/4 of the window has had useful range. That comes with a 2560 byte tag for the current projection & 2560 bytes for the previous projection for 10 FFT's per sweep. 50 FFT's per sweep would take 12800 * 2 bytes.
Motion tracking in a polar projection would take some doing, but be the most efficient solution. An additional 5120 bytes of ROM might be required for a lookup table to convert the polar pixels to square pixels for motion tracking.
Then, some 1024 bytes of scratch memory might be required, bringing it to 60416 for the 50 FFTs per sweep or 19456 for the 10 FFTs per sweep.
To rotate the FFT's & motion track a square projection would take 256kbytes to retain the full resolution. It would involve a similar lookup table to only track filled pixels.
No matter how limited the microcontroller, the resolution & speed of the sampling can always be scaled down to fit. The difference is only in the resolution of the output, not whether it can be done. The memory requirement could fit in the Papilio, but it seems it could be just scaled down to fit in an STM32.
The 256 point FFT is 1ms with the unknown matters probably taking 1ms, giving 50 FFTs per sweep, but increasing the polar projection to only 6400 because of the reduced window size. The polar lookup table would grow to 6400. The resolution would be awful.
The computational requirement for simultaneously tracking motion would slow down the FFTs below these numbers. The memory requirement can be calculated by a formula:
WINDOW_SIZE * 8 + WINDOW_SIZE / 4 * SWEEP_COUNT * 4 + 1024 + 1024 + 2048
Another lookup table would be required for the magnitude calculation & another 2048 byte lookup table is for the VCO curve. The high end 1024 window size with 50 windows per sweep would be roughly 63488 bytes.
The FPGA would definitely get finer resolution, despite more constrained memory. But the brief experiment with VHDL showed it's very time consuming. The FPGA also needs ADC's & a DAC. It may be more efficient to use a microprocessor for the analog I/O.
The very best resolution would come from the FPGA scanning I & Q output from 2 receivers. Handling 2 radar modules would take 8 op-amp circuits multiplexed into 4 ADC's. It's also equivalent to oversampling a single I output 4x.
Redoing everything in C & VHDL would not be appealing either, leaving the size of the board as the mane factor. The minimum number of sweeps per revolution is required before anything else can be known, so you look for the easiest way to determine that.
Sep 03, 2013, 04:17 AM
Follow These Tips To Save The Most Money On Restaurants
Would you like to go to Greece or maybe Brazil? This information will explain the nittygritty details you should know to get the best deals on airfare, lodging, meals, and attractions within the destination of your liking. You will save a small fortune by researching your travel options before you decide to step out the leading door.
Female travelers can get by having a very light wardrobe if they remember to pack the 2 essentials: a pair of black slacks and a black skirt. Any type of shirt, whether casual or dressy, will match both of these basic items and then leave you prepared for just about any event or activity that may arise.
Check around on the social networking sites you frequent for just about any tips or recommendations from the area you're planning on visiting. You'll be surprised just what may come up. Ask exactly what the best hotels are, exactly what the best restaurants are, what tourist destinations you should visit. Friends usually give the best ideas!
When you are traveling for that holidays, pack as light as you can. Airline baggage limits are getting more and more strict using their weight allowances and packing lighter can save you time and money. If you're planning your holiday visit be with friends or family, consider shopping on the web and having gifts shipped to your destination. This will cut down on luggage and guarantee don't lose any carefully selected presents.
Knowing you have to fly, do your favor and wear shoes requiring minimal effort to consider off. Don't pick that day to wear your eyelet wingtips with hardtotie laces. Women can wear clogs or slipons; men should select a casual shoe style that can be easily slipped off and on with one hand.
Now that you know what to look out when ever planning your trip, you can start taking into consideration the fun you'll have when you get there. The initial step to having a lot of fun on any trip would be to plan right. Keep these tips in mind to make sure you don't forget anything!.
Sep 03, 2013, 05:47 PM
is that 1024 pts per line, or 1024x1024? not clear what you mean by a sweep.....but 1/0.01 = 100 . best to figure out what resolution you want, then divide by factors of 2 until you get there, since the standard FFT algorithm (cooley and tukey?) runs much faster working with powers of 2. doing cross-correlations in Fourier space (convolutions) will give you positions of "peaks" to much better than 0.1 resolution element and are very fast....
Discussion Two thirds required a required amendment. rcjetpilot Life, The Universe, and Politics 42 Feb 09, 2013 02:06 PM
Discussion Computer Requirments for HD Video Editing? rcbif Aerial Photography 6 Jan 31, 2012 04:18 PM
Discussion Computers requirements dusty IV Simulators 6 Jan 15, 2009 05:43 PM
New AP plane required - task specific - input required!!! Scott Clarke Aerial Photography 58 Apr 10, 2005 02:43 PM
Transmitter requirements for connecting with computer ronrc Simulators 4 Nov 29, 2004 11:32 AM
